Homemade Wood Metal Mini Lathe Projects DIY Collet ER11 Headstock Chuck Spindle
Materials:
1 pcs motor 50 watt take from old hand drill
1 pcs aluminium alloy 42 mm x 80 mm x 12 mm
2 pcs Aluminium 80 mm x 80 mm x 12 mm
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
1 pcs Aluminium 200 mm x 80 mm x 10 mm 1 pcs Aluminium 100 mm x 80 mm x 10 mm
2 pcs rod shaft 12 mm x 300 mm cnc linear rails CNC rod
2 pcs LMK12UU 12mm flange bearing CNC Flange Linear Bearings Flange
https://youtu.be/1ovXxhRBAmo
https://youtu.be/npfh-IJwDn8
https://youtu.be/WCOzH-lYmSo
https://youtu.be/Z_BUZcQAjgY
