Homemade Mini Wood PCB Milling Router Mill DIY X Y Z Stage Frame Axis Slide CNC Aluminium Alloy
Homemade Chuck Spindle Collet ER11 here:
Homemade X Y Axis Slide Milling Router Mill here:
Materials:
Z Axis travel 90 mm
1 pcs SFU1010 Ball Screw Nut 1005 for RM1010 200 mm travel 90mm
1 pcs aluminium alloy 45 mm x 45 mm 250 mm
1 pcs LMK25UU 25 mm flange bearing CNC Flange Linear Bearings Flange Linear Bush
1 pcs SHF25 25 mm Horizontal Shaft Support CNC
More Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
https://youtu.be/YZ59g0b14Yc
https://youtu.be/Dk6cB6YIAsk
https://youtu.be/Pl5BYQ6KMXs
