Homemade Mini Milling Router Mill DIY X Stage Frame Axis Slide CNC Aluminium
Materials:
2 pcs Aluminium Profile 400 mm x 20 mm x 20 mm
2 pcs Aluminium Profile 340 mm x 20 mm x 20 mm
1 pcs Aluminium 200 mm x 200 mm x 6 mm for top
1 pcs 330 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 300mm with Copper Nut
1 pcs Nema 17 42BYGHW811 0.48N.m(70oz-in) 48mm 2.5A for 3D printer and cnc router mini motor step robotic
1 pcs ID6.35*8mm D19*L25 Aluminium CNC Stepper Motor Flexible Shaft Coupling Coupler Encoders Engraving Machine Coupling
2 pcs 12 mm 12 x 400 mm linear shaft 3d printer cylinder linear rail linear shaft axis cnc part
4 pcs Linear motion ball slide units block bearings SC12UU Bore size 12mm
4 pcs SK12 / SH 12 linear motion linear shaft end support match use linear horizontal motion round rod
More Homemade Mini Robotic Arm Laser Engraving Cutter DIY 3D Printer Machine Frame here:
https://youtu.be/9v7YzPYSPsE
https://youtu.be/IxmrPPjn-8I
https://youtu.be/NKqpAogR8zY
https://youtu.be/a3j-8kzHGnA
