Homemade Mini CNC Milling Router Mill DIY X Stage Frame Axis Slide Aluminium
Materials for X Axis DIY
1 pcs FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
2 pcs Aluminium Profile 300 mm x 42 mm x 12 mm
1 pcs Aluminium Profile 190 mm x 80 mm x 10 mm
1 pcs 330 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 300mm with Copper Nut
1 pcs Nema 17 42BYGHW811 0.48N.m(70oz-in) 48mm 2.5A for 3D printer
1 pcs ID6.35*8mm D19*L25 Aluminium CNC Stepper Motor Flexible Shaft Coupling Coupler
2 pcs 12 mm 12 x 350 mm linear shaft 3d printer cylinder linear rail linear shaft axis cnc part
4 pcs Linear motion ball slide units block bearings SC12UU Bore size 12mm
More Homemade Mini Robotic Arm Laser Engraving Cutter DIY 3D Printer Machine Frame here:
https://youtu.be/5e2zrFLnSNg
https://youtu.be/m-L65WAYn3w
https://youtu.be/IEI-11spdbI
https://youtu.be/PSAXR8iUuF0
