Homemade Wood Metal Mini Lathe Press Drills DIY Headstock Chuck Spindle Tailstock CNC
Materials:
1 pcs Aluminium 90 mm x 90 mm x 8 mm
2 pcs Aluminium 45 mm x 80 mm x 12 mm
2 pcs rod shaft 12 mm x 400mm cnc linear rails CNC rod
7 pcs SK12 12 mm linear rail shaft SH8A for XYZ Table CNC machine
1 pcs Aluminium 100 mm x 80 mm x 20 mm make hole 42 mm for drills
1 pcs Chuck drills 13 mm
1 old hand drill ( nice work)
More Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
https://youtu.be/zZLjPKJ0t1A
https://youtu.be/XTFnZoQflTI
- - - Updated - - -
https://youtu.be/hQ5oE49YpYY
https://youtu.be/Q46YLmL2ckE
