585,749 active members*
3,875 visitors online*
    Mar 2009
    11
    Surfacing and Containment
    I am scooping out a wood chair seat. Surfacing works properly, but I only want the surface machined not the entire seat. The toolpath flows up over the top and over the edge. Containment is needed and keeps the surfacing within the scoop.
    However, is there a way to draw containment lines within SC? Lines and arcs and polylines are easy and obvious in SC, but my containment is quite irregular and best represented with a spline.
    Sure i could create the containment in my CAD program easily enough, but would like to do it in SC so I don't have to switch around when it was not done before the export. Ideally a spline snapping to the edge of the surface all the way around would be best.
    Thanks, Greg
    Attachment 321892
    Mar 2009
    11
    Re: Surfacing and Containment
    OK so I have to answer my own question. Go to menu item "solids">"extract contour from edge" or face or loop as needed. Presto, contour (or lines or closed chain)created as needed for use as containment.
  1. Chip/Coolant Containment
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 11-18-2012, 03:54 AM
  2. Containment on a surface toolpath.
    By TXFred in forum SprutCAM
    Last Post: 09-26-2011, 06:52 PM
  3. contour toolpath containment
    By fjbart70 in forum Mastercam
    Last Post: 02-11-2011, 01:28 AM
  4. Pocketing/ islands/ containment???
    By slideleft in forum Mastercam
    Last Post: 03-20-2009, 03:34 AM
  5. Chip containment
    By Cold Fusion in forum Bridgeport / Hardinge Mills
    Last Post: 10-12-2005, 03:25 PM
