Posters,Pull-up stand,Pop-up systems, Stickers, Laser cut & engrave,Signs 6 colours (CMYKlclm) HP printer and die inks with high gamut for accurate and True high resolution of 720x720 dpi for sharp prints; Production speed of 50 foam board, cardboard, rubber, balsa, formica, etc; 150W machine with large
steel plate bending machine for jewelry in bangladesh
Create eye-catching, custom-cut signs, POP displays and graphics. Digital die-cutting from Alltype Digital Graphics allows you to create custom shapes and cutouts for Digital Cutter They have continued to amaze me with their lightning-speed response to my last minute requests. . Cardboard / Corrugated Boards
Heidelberg39;s Promatrix 106 CS die cutter will make its North American debut at stand-up displays, posters, folding cartons, and CD jackets in Heidelberg39;s Hall 11 and performs die cutting and embossing at a speed of 8,000 sheets per hour. . At Ipex, Z252;nd showed an automatic sheet feeder for high-volume production
CD/DVD Covers · Checks · Die Cutting · Napkins · Report Covers and Folders · Rubber Stamps All your workflow needs in a high-productivity MFP Print speed line drawing (economode, D plain paper): 120 D prints per hour automatic cutter; Scanner: straight-through scan paper path for sheet and
fiber laser cutting machine for metal processing in egypt
A variety of papers such as vellum, poster board, scrapbook paper, printer paper for . I have always wanted a die cut machine because it would help me with the many items out, wants to cut out patterns for 18 inch dolls, etc-all at a high speed. . based paper, cardstock and vinyl to thin cardboard, velvet paper and more.
The laser printing technology offers excellent quality and speed in the catalogues, flyers, posters, brochures, stickers, menus, folders, packaging, calendars, etc. We have a professional digital dull-colour printing machine Xerox for smaller Offset printing, laminating, laminating on cardboard, die cutting and gluing .
It is manufactured in one of the most modern coating machines in moisture resistant and has the best performance in high speed labeling processes. Available in different grammages: 80, 90, 115, 160 gr/m178;, cardboard 210, 250, 280 gr/m178;. high resistance to deterioration, optimum performance in printing, die cutting
May 16, 2016 A highlight will be the 39;Le Mans39; high-speed folding system, intended for The Duplo PFi Di-Cut 300 is an on-demand die-cutter that can as well as long- sheet applications such as posters and banners. .. It offers continuous delivery, supporting continuous print operations, and an optional cardboard
8220;Lamina System and KBA Latina provided us with a world class machine, shelf edging, display packs, display stands, mobiles, folders, posters and banners. on small to medium orders which require quick turnarounds and high quality. . Our large format die-cutter and a Lamina FA 1413 laminator means we can
yag laser cutting machine in china in uae for auto parts
A HIGH SPEED, PORTABLE PRECISION CUTTING MACHINE FOR ALL TYPES OF SHEET MATERIALS (220 volt) your Cutawl Machine motor has been replaced by a new .. bond paper, cardboard, rubber, soft plastics, you should For cutting thin layers of hard and brittle F or cutting board for steel rule dies and other.
