585,932 active members*
3,809 visitors online*
IndustryArena Forum > WoodWorking Machines > Wood Lathes / Mills > Homemade Mini Grinder Belt Wheel With DIY Heads Spindle With Old Motor Hand Drill
Results 1 to 2 of 2
    May 2016
    3
    Angry Homemade Mini Grinder Belt Wheel With DIY Heads Spindle With Old Motor Hand Drill
    https://youtu.be/lYuVpRZI0cA
    https://youtu.be/Jq_4cIcamYo
    Homemade Mini Grinder Belt Wheel With DIY Heads Spindle With old motor Hand Drill
    Homemade Mini Grinder Belt Wheel Frame here:
    And more Materials:
    1 pcs motor 50 watt take from old hand drill
    1 pcs Mounting L Bracket Mount 42 series Stepper Motor Holder for NEMA 17 Motor
    1 pcs BR 6.35mm x 10mm D25 L30 CNC Stepper Motor Shaft Coupler Flexible Coupling 6.35x10mm Motor Connector 6.35*10mm
    More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    Feb 2016
    381
    Re: Homemade Mini Grinder Belt Wheel With DIY Heads Spindle With Old Motor Hand Drill
    Cannot see any adjustment for belt roller alignment without perfect alignment belt will just slide to one side and shred against bearing housing, and changing that belt looks extremely complex so a basic £25 belt sander, inverted in a vice would be not only easier but cheaper and far more useable / usefull.
  1. Replies: 0
    Last Post: 05-20-2015, 01:28 PM
  2. ​Homemade Mini Press Drill for all Hand tools very cheap and easy
    By doitbymyhand in forum Wood Lathes / Mills
    Last Post: 05-20-2015, 09:47 AM
  3. Replies: 3
    Last Post: 05-19-2015, 11:17 AM
  4. Homemade wood mini lathe with hand Drill
    Last Post: 05-17-2015, 09:51 AM
  5. DIY Wood Mini Lathe Metal Axis Homemade Tailstock with Motor Drill
    Last Post: 05-14-2015, 04:18 PM
