584,842 active members*
4,565 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Help importing text from AutoCAD to AlphaCAM
    May 2013
    8
    I'm taking parts drawn in autoCAD and nesting and toolpathing them in AlphaCAM. Inside the parts contains text that I need but everytime I import a DXF or DWG the size of the test is growing/moving outside the perimeter of the parts once imported into AlphaCAM. Both programs are using the same text with the same name, .TFF extension and i'm selecting the same font on the 'Input CAD' window in AlphaCAM so i'm not sure why this is happening. I spent many hours trying to find a solution and have not found one yet. Has anyone else ever experienced this problem before or know of a solution? Thanks
    Apr 2015
    327
    Re: Help importing text from AutoCAD to AlphaCAM
    Hello,
    could you please attach your DXF?
    nice nickname
    Marek
    [email protected]
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Dec 2008
    3110
    You need to convert the text to "lines & arcs" to become geometry that can be "machined"
    I think the AutoCAD term is "Explode".....this would turn the font into geometry that is fixed and is not altered during the export / import operation
    - you may get lots of line segments due to a TFF font type
    - you may have to do it 2x for a dimension ( separate leaders from text, then convert text to lines )
    Does AlphaCAM have a separate location for fonts ( other than the c:/windows/fonts path ) ?..... it may not be using the same actual font
    You need to use the Express Tools Explode Text command on the text.
    The regular Explode command does not work with text.
    May 2013
    8
    Thank you very much Gerry that seemed to be the answer!!
  1. Importing Autocad into BobCAD
    By piertechpierre in forum BobCad-Cam
    Last Post: 01-03-2013, 06:15 PM
  2. trouble importing autocad dxf
    By mrdarreng in forum Torchmate
    Last Post: 09-06-2011, 04:10 PM
  3. Importing 3D from AutoCAD 2000
    By noisillator in forum Uncategorised CAM Discussion
    Last Post: 06-19-2009, 03:44 AM
  4. Importing AutoCAD into MC9
    By Linear360 in forum Mastercam
    Last Post: 07-30-2008, 05:32 AM
  5. Importing X & Y points to AutoCAD- how plz?
    By ImanCarrot in forum Autodesk
    Last Post: 08-09-2007, 02:16 PM
