585,763 active members*
4,364 visitors online*
    Jun 2016
    Machine for engraving raw crystals / gemstones ?
    Hi there
    I am looking for some guidance on how to make a crystal pendant similar to the ones in the photos I have attached. I know that it was created by using laser engraving and I am just wondering what machine I could use to do this myself? The gemstones are quite small (3 to 5 cm across) and sometimes not flat.
    Thanks very much!
    Feb 2016
    381
    Re: Machine for engraving raw crystals / gemstones ?
    I would imagne only a laser engraver is suitable as other machining may well cause the crystals to to splinter or crack, type of lasers depend on type of crystals a google of natural materials suitable for laser engraving would probably give that answer, but I suspect that a minimum requiremtent would be a co2 laser rather than any of the lower priced diodes available.
  1. HELP LAPPING CZT crystals
    By lapper/polisher in forum Material Machining Solutions
    Last Post: 02-28-2010, 04:27 AM
  2. Can crystals be tapped?
    By ImanCarrot in forum Glass, Plastic and Stone
    Last Post: 09-19-2009, 04:16 AM
  3. laser subsurface engraving machine for 3D crystals
    By lindagstar in forum Want To Buy...Need help!
    Last Post: 10-31-2008, 09:54 AM
  4. 20Mhz crystals
    By PsyKotyk in forum PIC Programing / Design
    Last Post: 11-09-2006, 02:51 AM
