does anybody how to turn of the vacuum so u can clamp stuff and dont get an alarm?
its a old masterwood
thanx
thanx
you will probably have to bypass the vacuum switch.
Yeah, it won't run without vacuum, unless you bypass the switch.
Was kinda afraid of that
when input 9 comes on output 2 & 4 must go out to trick the system, thats what happens now. Spindle is output 9 so when the spindle starts the currents has come off at the vacuumsensor of 1 off the zones prefer both actually. I also have the pezzi stretti option on the machine. that are 2 clamps for short pieces. so then the vacuum is off i presumme would be silly if when u clamp vac has to on? that system doesnt work also any more
when the spindle starts then it the error that vacuum is off 2.1.1011 so i think it has to be a parameter setting. at generic 4 i have nearly the hole field empty for example NPRG_BAR and thats where "pezzi stretti: turned on
anybody an idea?
In my error search...I see this post.
In my eror list, 1011 error is insuficient oil level.
My mw atlas L is equipped with a
Auto oil pump.
I see this error code at the first time power on the machine.
Enviado desde mi SM-G900F mediante Tapatalk
