585,729 active members*
4,704 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > WORKING: MassMind Servo Conversion Kit
    May 2005
    1397
    The MassMind.org Servo System is released! It's tested and WORKING and PCBs / Kits are available. It is currently a two part system: PID controller, and non-contact encoder. We are working on a DC motor controller that should manage nearly 1 HP. (40 volts, 18 amps) to have a complete solution, for now, just use it with any standard H-BRIDGE or other motor driver that accepts PWM and direction.
    This isn't a "turn key" hot from China, packaged in a slick metal box system. It's for DIY, Makers, Hobbyists, and people who like putting things together. It's low cost, good quality, and very very very well supported. Ask anyone... we support our customers.
    BOB PID CONTROLLER:
    techref.massmind.org/techref/io/servo/BOBPID.htm
    The BOB PID is a very low cost, but quite capable, PID servo controller, which can replace stepper motors in any standard application, such as 3D printers or CNC machines.
    • Serial and step / direction inputs.
      - The serial interface, via any TTL to USB adapter, allows for easy tuning of the P.I.D. constants and setting options like the polarity of the output direction signal. It also support a bootloader for future firmware updates and new abilities / optimisation.
      - The step / direction input allows its use in any application where a standard servo driver was intended. Our Pololu adapter cable makes plugging it into a RAMPS / GRBL or pretty much any other motion controller very easy.
    • Position input comes from a standard quadrature type position encoder, like our non-contact, high speed magnetic ENC1 connected to the motor or output shaft. Up to 73,000 edges per second or 18,000 lines per second are supported with the current 0.93 firmware. That supports up to 1,100 RPM with a 1000 line (4k quad) encoder, or well over 10,000 RPM with our 360 quad ENC1.
    • The output is PWM speed and direction suitable for any standard "H-Bridge" motor driver.
    Limitations:
    • Top speed limited by processor power and code efficiency. Future updates will improve the top speed.
    • No autotuning of the PID loop. Might add that in the future.
    • Could support a local user interface with a cheap LCD panel and some switches if people want that... Probably can't update the display and move at the same time.
    • Probably needs some tweeks to work with an ESC... might work fine... we honestly haven't tried that yet. Let me know if you want to.
    The complete kit is $15.95, the PCB is $8, uses a $2.50 PIC.
    ENC1 ENCODER
    http://techref.massmind.org/techref/...s/enc/ENC1.htm
    Based on the amazing AS5134 chip, this encoder supports 76875 RPM, 360 CPR/counts per revolution (with 4x decoding) quadrature rotational encoding. It senses the position of a two pole radially magnetized disk over a full revolution using a hall effect sensor array. The sensor signal changes are converted to a digital quadrature signal, and the position information stored as absolute position data on some registers, which are readable through a 3 wire synchronous serial interface. Standard quadrature Index, A and B phase signals are also generated just like any standard encoder.
    • 76,875 RPM (!!!)
    • Non-contact magnetic sensor.
      • No need to mechanically attach to a shaft, just epoxy a small magnet in place. Great for motors with one shaft.
      • Alignment isn't critical. As long as the magnetic field is generally over the chip, within 1/2 inch, it will work quite well
    • The onboard LED indicates that the board is powered, and provides easy testing the alignment of the IC with respect to the magnet.
    • Multiple connection / cable options are supported.
    • Standard Quadrature A and B phase outputs, as well as several digital modes.
    Limitations:
    • Fairly low resolution: 360 positions per revolution (1 degree). Honestly, that just helps the PID controller manage higher RPMs. For most applications 360 is plenty. Steppers are 200 to 400 in the real world, as microstepping is NOT positionally accurate. Just as an example, on a machine with a lead screw drive, having a 10 tpi thread, the resolution would be 0.0003 in.
    $20 kit
    VIDEOS
    2,300 RPM real world encoder test
    www.youtube.com/watch?v=6iYVkAmXD4w
    Small DC motor with HID encoder run by BOB PID
    https://www.youtube.com/watch?v=TjflUkI--Sw
    Large DC motor with ENC1 run with BOB PID from RAMPS/Marlin.
    https://www.youtube.com/watch?v=rnwYqGB3bXw
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Jun 2008
    467
    Re: WORKING: MassMind Servo Conversion Kit
    You guys are awesome, thank you.
    Live from downtown Burbank, home of the endless cup of joe.
    JoeyB
    A doughnut a day keeps the doctor away.
  1. WORKING: Chinese blue box CNC after MassMind.org driver upgrade
    By James Newton in forum Chinese Machines
    Last Post: 06-03-2016, 06:48 PM
  2. THB6064AH Stepper Motor Driver by MassMind.org
    By OldSalt1945 in forum Stepper Motors / Drives
    Last Post: 05-26-2016, 09:46 PM
  3. Massmind.org 6064 stepper driver kit buildlog and review
    By TroyO in forum Open Source Controller Boards
    Last Post: 04-03-2015, 06:45 PM
  4. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
  5. Value of series 1 BOSS w/working modern CNC conversion?
    By SRT Mike in forum Bridgeport / Hardinge Mills
    Last Post: 12-11-2005, 05:47 AM
