585,978 active members*
4,401 visitors online*
IndustryArena Forum > Community Club House > Computer Technology > USB, RS232, PARALLEL etc > Yasnac 2000B DB25 parallel port to tape reader cable
    Feb 2016
    115
    Does anyone have the pin out to make the yasnac 2000B tape reader to parallel port cable? My DNC software is capable of sending through my parallel port I just need the cable
    Feb 2009
    6028
    Re: Yasnac 2000B DB25 parallel port to tape reader cable
    Not sure that's possible on a B . They needed a BTR (behind the reader) I think to work.
    Sent from my A3-A20FHD using Tapatalk
    Feb 2016
    115
    Quote Originally Posted by underthetire View Post
    I think it is possible the software just emulates the tape reader, I Dont think you can drip feed though, the BTR's are way over priced for late 70's early 80's tech they shouldn't be over $50.00 bucks and most places are wanting over $1000.00 that's ridiculous. I only gave $200.00 for the lathe. lol
    Feb 2016
    115
    I'm going to try and wire into the tape reader head light sensors with an ardunio and a 74HC595 8bit shift register, and send code to it in EIA-RS244-A binary format to make it think its reading tape in theory it should work, someone else on here made it work on an old fanuc control so I'm going to give it a shot, I just can't see giving $1000.00 + dollars for a piece of $50.00 hardware just because it hooks to a CNC
  1. Yasnac 2000B needs a RS232 port
    By Redzilla in forum Mori Seiki lathes
    Last Post: 07-31-2016, 06:55 PM
  2. DB25 parallel port data direction
    By GASANT in forum CNC Machine Related Electronics
    Last Post: 07-06-2014, 05:53 PM
  3. MACH 3, EMC 2 / CNC Breakout Board, DB25 Parallel Cable
    By Robiz in forum News Announcements
    Last Post: 08-30-2011, 03:10 AM
  4. MACH3, EMC 2 / CNC Breakout Board, DB25 Parallel Cable
    Last Post: 07-08-2011, 04:40 PM
  5. MACH3, EMC 2 / CNC Breakout Board, DB25 Parallel Cable
    Last Post: 06-28-2011, 03:34 PM
