585,996 active members*
4,657 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > 4th Axis Radial Milling - How to?
    Apr 2008
    196
    I have cut these parts successfully in AlibreCAM, & in VisualCAD/CAM 2016 using the parallel finishing toolpath. In my previous installation of AlibreCAM, I was able to program this using the radial milling options, but in the stand alone application I cannot seem to do so. I was looking to run one using a different method to see if the finish was better. I make these screws from different plastics, Delrin, HDPE, UHMW, and others, on a 4 x 8 CNC router with a DIY rotary axis. A lot of sanding was involved after the parts are machined, then heatedwith a heat gun to get the desired finish. Also, the Feature List on the web site shows 10 4th axis milling options, & I only seem to have 7 to choose from.The file can be downloaded here - https://app.box.com/s/9gz5b68c7adzf61vq5uzlrmq6jq79pqh
    Apr 2004
    5737
    Re: 4th Axis Radial Milling - How to?
    Have you asked Mecsoft tech support about these issues? That would be the first thing I'd do.
    Andrew Werby
    Website
  1. MILL TURN RADIAL MILLING
    By mousongie in forum EdgeCam
    Last Post: 09-16-2015, 10:13 AM
  2. Using a Honeywell Compass as a Radial Axis Encoder
    By towertek in forum Mitsubishi controls
    Last Post: 04-06-2014, 01:39 PM
  3. Replies: 1
    Last Post: 03-02-2014, 06:46 PM
  4. Replies: 0
    Last Post: 10-17-2013, 02:29 PM
  5. radial array around axis
    By panaceabea in forum Solidworks
    Last Post: 07-19-2007, 08:53 PM
