I was doing a simple job using imperial units but when posting the machine barely moves, it interprets inches as mm it seems. The post processor I am using is Axiom-MADcam-Postv5_2.txt. There is a scaling function but scaling everything to 25.4 seems to move the initial distance may be correctly but then barely moves again. Do I need to modify the pp to include both a G20 command and the scaling to 25.4? In Rhino I set up the units as inches, there does not seem to be a similar setting for MadCAM.
I have the following setup: Axiom Autoroute AR8 CNC machine that uses the RichAuto A11 controller. Software are Rhino 5 latest version & and MadCAM latest version 5.0.2015.417. The RichAuto controller only understands metric but that should not be a problem since I have used Vectric Aspire software with imperial units and it posts fine. The pp for the Vectric software is AXIOM_HHC_CNC_VCPASPIRE.pp. I had done all the previous jobs using Rhino/MadCAM with metric units and the Axiom post processor I have works fine for that. I prefer to standardize on Rhino/Madcam but would like to be able to use imperial units. Please advise.
Thank you for your help.
