585,752 active members*
4,061 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What is a suitable (cheap) driver for a 14V, 0.7A unipolar stepper motor + more Qs
    Apr 2016
    Hello everybody,
    I've managed to salvage an old Nema34 Minebea unipolar stepper motor (6 wires), which has the following characteristics: 14V/phase, 0.7A/phase.
    I'm planning to do a project with an Arduino board (not exactly a CNC machine, but I do need precision in driving a lead screw), and I was wondering what kind of a driver I should get, provided that I want to minimize costs on the one hand, but I do want it to perform on the other.
    If I understand correctly:
    1. 6-wire unipolar motors can be hooked up to operate as bipolar motors, either in full-coil (leave the center tap hanging at each phase) or half-coil (connect to one of the phase wires and the center tap at each phase) mode.
    2. Due to the above, I could get away with relatively cheap, mainstream (bipolar) drivers, like even the Easy Driver (750mA max), or the TB6600.
    3. The low current rating of 700mA means that it has high inductance, i.e. it will not run very fast.
    4. Connecting it in half-coil mode would retain the same characteristics as unipolar operation mode, but full-coil connection would result in more torque, but also 4 times the inductance, making it even slower (yet more powerful).
    I was wondering first whether this is correct, but also:
    a. What current should I supply to the full-coil bipolar connection of the motor? Is it still the same 700mA?
    b. Which driver would you recommend for me to get?
    Thanks in advance.
    Apr 2004
    5734
    Re: What is a suitable (cheap) driver for a 14V, 0.7A unipolar stepper motor + more Q
    It's hard to say whether this will work for you, since you don't say what you're trying to do. But the first thing would be to find out more about that motor you want to use. I tried looking it up in this chart of older Minebea steppers:
    Minebea Stepper Motor Specifications
    but couldn't find one rated at 14v. The nameplate voltage rating on steppers doesn't really mean much anyway; you'd typically feed them a whole lot more. You mention that it has high induction; that means it will take a lot of voltage to run it effectively, which could rule out the cheap drives you want to use, since they typically won't tolerate much voltage. If the main object is to use those drives with an Arduino, figure out how much voltage they'll handle, and shop for a motor that won't demand more than that, using the equation 32 * (square root of) induction = optimal max supply voltage.
    Andrew Werby
    Website
    May 2005
    1397
    These pages may help:
    Different connection options:
    techref.massmind.org/techref/io/stepper/connections.htm
    How to work out which wire is which:
    techref.massmind.org/techref/io/stepper/wires.htm
    Easy Driver isn't bad. I don't recommend the TB6600... they are... twitchy. Also some of the larger Pololu drivers will probably manage that motor. And of course, my drivers would be best... ,o)
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. Linistepper - cheap unipolar microstepping driver
    By lietuvys in forum Open Source Controller Boards
    Last Post: 10-04-2014, 08:13 PM
  2. Unipolar Stepper Motor Driver ( SLA7078MPR )
    By RCForge in forum Open Source Controller Boards
    Last Post: 02-18-2013, 11:57 AM
  3. Cheap stepper motor controller and driver
    By webbyguy in forum Stepper Motors / Drives
    Last Post: 08-18-2010, 07:20 AM
  4. Help on driver for this unipolar stepper motor
    By percebon in forum Stepper Motors / Drives
    Last Post: 03-09-2007, 01:41 AM
  5. Is there some cheap stepper motor driver?
    By ezland00 in forum CNC Machine Related Electronics
    Last Post: 03-26-2004, 03:20 AM
