585,982 active members*
4,722 visitors online*
    Mar 2013
    126
    Laser tube end broke off
    I was sliding the water tubes on and it broke right off! I thought
    I read somewhere that it can be reattached??? or is it a dead tube now??
    Attachment 323272
    Apr 2004
    475
    Re: Laser tube end broke off
    If it didn't open up the parts where the gas is, probably ok to epoxy back together. If the gas escaped, it's dead.
    Sent from my ASUS_Z00TD using Tapatalk
    Feb 2016
    381
    If the gas containing section is intact it may be repairable with plenty of epoxy if it can be made completely waterproof, lots of voltage involved mainly at other end of tube but still a major consideration, at 20% on 40w system I have measured over 10,000v @ 40watts not somewhere you should risk any chance or water ingress so proceed with care.
  1. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  2. Laser broke, need help ID'ing part..
    By kwiktsi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-25-2013, 06:55 PM
  3. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
  4. Z-axis oil tube broke - need to identify and source replacement
    By torinwalker in forum Maintenance DIY Discussion
    Last Post: 02-10-2011, 07:10 PM
