Hi guys ! Thank you everyone for pushing and pulling things around !
I am a complete newbie and if you see something displaced with my thinking or else, please, feel free to correct me.
I am building a cnc machine and I came closer to mount my spindle on the Z axis. I have bought the spindle from Germany, but it is made in Italy. It is a 21 years old Giordano Colombo spindle. It is a 3phase 220v(5hp)-330v(7hp),12A,12000rpm-18000rpm at 200Hz and 300Hz motor. It is like this one Giordano Colombo Spindle Motor RV 90.2.SB CNC Mill Engraver Router w/ Set Collet . The seller told me the motor runs alright.
I have bought for this spindle a frequency inverter Yaskawa V1000 -- CIMR-VCBA0018BAA , 200 V, CT: 17,5 A / 4 kW, IP20.
I have managed to set them right I believe(but I am not sure) and I discovered that the rotor is getting hot, no matter how fast the motor works. In about 30 60 seconds it starts to heat up. Initially I thought the problem are the bearings, but then I let it to heat up a bit in the bearings cage and I dismantled it quick and I have found out that the rotor was the one that built up heat and not the bearings.
Has any of you used an Yaskawa drive ? Maybe some settings are bad, I have successfully performed the Auto-Tuning and it runs quite alright, but from time to time It sounds like the speed gets lower and rise up again.Thing is on the display, the V and the Hz and the A are constant when this happens. Without load the motor eats up 5.5 A .
Some said my rotor is in shortage, but there are no visible cracks in the aluminum cage and no color differences on the surface of the core.
