I'm looking for any feedback on a steel frame fixed gantry design (below). My goal is to use this machine primarily to work with soft metal and a little bit of mild steel.
This is still in the design phase and I'm happy to modify.
[If you build this stoutly enough it might be able to cut steel to some extent. But there are some problems with this design.]
Design
- Overall approx 48" long. 40"wide and 20" tall
- Working area approx 29x24"
- Table made from 1" Al, approx 29x24".
- Crossmember is 4x8" hot rolled rectangular tube (1/4" wall)
- Pillars - 4x4 hot rolled sq tube (3/8" wall)
- Base - side runners (2x4x0.120")
Specific Questions:
1) I have yet to select a spindle and would like input here - vendors, type, size etc
[Spindles for cutting steel are not usually sold separately from the machines they go on. But you'll want something with a large and powerful motor and a pulley cluster to trade speed for torque, which mitigates against the sort of Z axis you've drawn here, that's more suitable to a high-speed router.]
2) Rails - looking at HiWin made in Taiwan imported from China.
Are these overkill in size? Would 15mm do?
Gantry (x) 1000 x 20mm
Gantry (y) 1200 x 25mm
Gantry (z) 500 x 20mm
[The rails are fine, but the way you're mounting them isn't going to work too well. Hot-rolled steel isn't flat enough to mount rails on directly. And those supports under the table aren't nearly beefy enough to withstand the vibrations of cutting metal.]
3) Ballscrews - C7 rolled imported from China.
Gantry (x) 20mm (1000mm)
Gantry (y) 25mm (1200mm)
Gantry (z) 20mm (500mm)
[C7 rolled ball screws, while inexpensive, are not very accurate. You need to decide if your projects are going to require more accuracy than they will give you. C7 rolled ball screws will be off by +/- 50 microns over 300mm (about .002" per foot - see
http://lin-tech.hennlich.cz/uploads/...gkeiten_54.pdf . That, of course, is when they actually meet the standard. If you're shopping from the cheapest suppliers in China they may have skimped on quality control. Here are some more considerations to mull over when thinking about ball screws:
Ball-screw basics: Debunking the myths | Mechanical Drives content from Machine Design ]
4) Steppers - Nema 23 (580 Oz). Are these big enough?
Figure the gantry with motor will weigh about 70 lbs
Figure the table will weigh about 50 lbs.
[It doesn't really matter how much your bridge weighs, since it doesn't need to move - more weight is better, actually. The weight of the table will vary depending on what's loaded onto it. If you're planning on machining big hunks of metal, you'd better plan for more weight there. It's usually best to actually build your frame before worrying about the motors and drives; things can change in the course of a build, and you don't want to be stuck with components that won't work for your upgraded design. In this case, servos might be a better bet than steppers.]
5) Would steel 1/2" be a cheaper alternative to a 1" Al table?
[It would definitely be cheaper...]
Many thanks!
Adam
