585,599 active members*
3,572 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Busellato/Genesis Evolution help please!
Results 1 to 10 of 10
    Jun 2016
    Unhappy Busellato/Genesis Evolution help please!
    We just bought a second-hand Busellato jet something running with Genesis Evolution. I design cut out panels using Google Sketchup, and we believe I can export a .dxf and import that into Genesis to create a .cnc, except it just throws out an error code an does nothing.
    I downloaded CamBam as an interim programme and have exported the g-code from that but still Genesis does nothing....
    Any advice? Bear in mind I'm not a programmer, nor cnc trained in any way (I just design things).
    RD
    Jan 2013
    19
    Re: Busellato/Genesis Evolution help please!
    Hello, use a Busellato Optima with Genesis v7. Normally amount profiles from Autocad DXF without problems. If you want to send me the DXF files generated by Google to be able to analyze so that it can figure out where the problem lies. (Translated by 'Google Translator', sorry but I do not know English well)
    Jun 2016
    Hi Maverickfly,
    The Google Sketchup .dxf is here:
    https://www.dropbox.com/sh/76bv8j3kq...VFS1fpO9a?dl=0
    Grazie per qualsiasi consiglio che potete offrire
    Rhiannon
    Jan 2013
    19
    the DXF-3D file is very complex and it is likely that your version of genesis is not able to convert it. I tried it with my version 7 and the result is this program cnc you send. In any case you have to simplify the design by removing all duplicates (overlapping lines) and then exploding the remaining before importing it into genesis.
    download link cnc https://www.dropbox.com/s/500jovmh583li90/1.cnc?dl=0
    Jun 2016
    Hi maverickfly,
    Thanks for that. Our software must be too old as it wouldn't run your file either, just produced an image with lines all over it.
    I have found a programme called CamBam to change the dxf and export to Genesis Evolution however Evolution doesn't seem able to read the start points we have specified.
    Any ideas?
    Apr 2015
    327
    You can try Alphacam.This software can export directly to your Busellato from dxf and also solid model. If you will help with this let me know.
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Jan 2013
    19
    Which version of Genesis Evolution uses?
    If you have a version of the 4-up, the file format is not g-code, but it is a not-standard iso
    Can you get me a file which CamBam order to analyze it?
    Regards
    May 2013
    15
    Quote Originally Posted by maverickfly View Post
    Regards
    I have a latest Genisis evolution 8.0 software let me know if you need it.
    Apr 2011
    Quote Originally Posted by RookieCAD View Post
    I have Genesis Evolution 6.4 and again lost another PC. It's getting harder and harder to find an old pc to run windows xp for this old software. Any chance someone can help with a newer version to at least run this on windows 7?
    Nov 2018
    Hi
    I need this program
    But it works well with any genesis evolution
    And can I install it on my laptop?
  1. Busellato Genesis Evolution
    By maverickfly in forum CNC Machining Centers
    Last Post: 08-05-2022, 04:07 PM
  2. Genesis Evolution
    By sleblanc in forum CNC Machining Centers
    Last Post: 08-14-2017, 11:18 PM
  3. genesis evolution help cen-cal
    By forate48 in forum Mentors & Apprentice Locator
    Last Post: 08-14-2017, 11:11 PM
  4. Genesis Evolution 4.0
    By NoProblemo in forum Commercial CNC Wood Routers
    Last Post: 02-26-2016, 10:56 PM
  5. Genesis Evolution
    By sleblanc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-02-2004, 09:58 PM
