Guys I screwed up.
I was trying to drill out a hole in 17-4 using a HSS drill bit. The bit was 0.070. It would have only been removing 0.004" on each side. I ended up breaking the bit in the hole. I have to eventually tap this whole all the way through. It's a through hole.
How can I remove this drill bit without messing up the part? It was an expensive DMLS printed part. What about alum or any of those other fancy chemical techniques? I guess I could drill it out with a carbide drill bit. I should probably invest in some carbide drill bits anyway.
Any suggestions?
