585,975 active members*
4,596 visitors online*
Results 1 to 9 of 9
    Serious Issue :(
    So One a side note I had a problem today with my small cnc machine and I am not sure why it happened can anyone let me know as to why this happened?
    hello everyone I had something bad happen today I waited 3 days for this piece of material and look at what happened
    Can anyone tell me what happened?
    I designed in Fusion 360
    sent to Universal Gcode Sender Version 1.0.9/ Nov 11 2015
    and cut on X-carve
    any help would be appreciated thanks
    Jun 2014
    777
    Re: Serious Issue :(
    Can you attach the gcode to this post.
    yes I can here are the 3
    well actuall it wont let me upload a .nc file any suggestions?
    Jun 2014
    777
    Firstly though not the issue here but you should really get into the practice of outputting all operations into a single file. If you have toolchanges use m6 macro, for manual toolchange some control software you select it to pause and wait for cycle start when m6 in called upon in code. Or you may need to modify the m6 macro to work to this effect.
    Just rename the nc file as .txt I believe.
    I'll see if I can open your code when I'm back in the office
    okay thanks
    and yeah I know I am pretty new to cnc but with my large cnc that I just bought I need to learn gcode a bit better I will be running mach3 on that machine but I need to learn alot for now it just seemed like the easy way to get around manual tool changes by breaking up the files by tool
    Apparently Universal G-Code Sender didn't like the g-code format.
    werid I have never had a problem like this before with universal gcode sender
    finally got it to work today lol
  1. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  2. Replies: 1
    Last Post: 01-08-2016, 06:58 AM
  3. Little issue with G10
    By Myrmidon in forum Fanuc
    Last Post: 03-16-2015, 02:34 AM
  4. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
