Hello,
I have retrofit my old lathe. The cnc-control is about Mach3 with 2 printerports the os is win7 home pro. In the diagnoctics mode I can see the spindel speed sensors working. In the manual or automatic screen does the spindle speed display not work. The spindlespeed is set manually with a mechanical gearbox. The machine with Mach3 works good, but only the real sindlespeed display is not working. I tested with fast and low speed.
Does someone knows what can I do?
Hans
