585,555 active members*
3,302 visitors online*
    Jan 2016
    53
    G02/G03 Arc Formula
    I was looking for a formula to calculate Arcs and came across this reference: How to program arcs and linear movement in G-Code manually - All
    I've been doing manual Arc calculations and writing my own gcode and have successfully made a lot of Arcs on my laser machine. So I feel I have a pretty good handle on manually writing gcode to produce Arcs.
    However, the formulas on this web page don't seem to work for me and I can't figure out why. When I manually run the numbers on one of my Arcs (that work on my laser machine) and then plug those numbers into the formulas provided on this web page, the Arc G03 values are very different.
    From the web page:
    Formulas
    1) Xs=Xc+(R*cos(Theta1))
    2) Ys=Yc+(R*sin(Theta1))
    3) Xe=Xc+(R*cos(Theta2))
    4) Ye=Yc+(R*sin(Theta2))
    5) I=(Xc-(R*cos(Theta1)))-Xc
    6) J=(Yc-(R*sin(Theta1)))-Yc
    While I can manually create the Arc gcode, I'm not very good at math so I can't 'debug' these formulas. So I thought I would ask if anyone knows of some other G02/G03 Arc formulas that I can try?
    Thanks...
    May 2015
    1422
    Re: G02/G03 Arc Formula
    If your machine is set for incremental arc I/J then 5 and 6 are correct but simplify to just Xc-Xs and Yc-Ys, respectively.
    If your machine is set for absolute arc I/J then they need to be Xc and Yc.
    Usually shows up as a big curve that's the part of the circle which /shouldn't/ be run.
    Jan 2016
    53
    Thank you...!!!
    May 2015
    1422
    Don't trust me to the point of putting tools and materials in the way of those - do some test previews etc first!
  1. Formula
    By fdonosos in forum Okuma
    Last Post: 07-28-2011, 01:54 PM
  2. looking for a Formula
    By rusticr6 in forum Haas Mills
    Last Post: 10-18-2007, 04:23 PM
  3. Need a formula
    By Turk88 in forum Community Club House
    Last Post: 06-15-2006, 02:06 PM
  4. What is the Formula?
    By widgitmaster in forum Uncategorised MetalWorking Machines
    Last Post: 03-24-2006, 05:35 AM
  5. formula please!
    By turmite in forum CNC Machine Related Electronics
    Last Post: 11-22-2003, 08:45 PM
