585,752 active members*
4,213 visitors online*
    Apr 2006
    109
    Hurco KMB1 dnc
    Anyone out there that can help???
    Apr 2006
    113
    What do you need to know
    Apr 2006
    109
    Well I want to run gcode to my kmb1. I already have my 9pin on pc going to my emulator card. On the back of the machine the 2 ports have phone line wire spliced into them both. Now can I use that or do I need another pc with a 9pin on it, and what type of free dnc should or would work.
    Apr 2006
    113
    my DNC Came with my cad cam....To use G-gode you have to load a and here is another linkmaster program thru your serial port not the emulator...,I have a serial port and cable hook up to my computer...the parameters will need to be set so the computer will communicate with the machine here is a link where you can doanload master programs... http://www.amtsinc.com/home.html .... and here is another link..these people have good phone support...and it is free
    http://www.midwestcnc.com/... hope this helps
    Jim
    Apr 2006
    109
    Ok so if I run another 9 pin from machine (the round plug) to my pc 9 pin it wont mess with my emulater card that I use to load the master. I have the master for conversational,gcode, and 6000 rpm spindle. If it wont be bad for my emulator to plug and un plug the 9 pin then I will wire it I already have the pin out for the 9 pin. Thanks Jim, I will let you know How I far.
  1. help with bobcad on a hurco kmb1
    By jpcuttergrinder in forum BobCad-Cam
    Last Post: 01-25-2007, 04:35 AM
  2. Hurco KMB1 question
    By jpcuttergrinder in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-02-2006, 11:39 PM
  3. Hurco KMB1 with bx upgrade
    Last Post: 10-15-2006, 04:38 AM
  4. Hurco kmb1 BTR ???
    By drill in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-10-2006, 06:42 PM
  5. Hurco kmb1 help!!!
    Last Post: 01-03-2006, 06:40 AM
