584,830 active members*
5,557 visitors online*
    Apr 2014
    215
    Uccnc - g20/g21 or g70/71
    I've noticed that g20/g21 or g70/g71 is not implemented.
    I was wondering if a macro could be set up to store the current units per axis, then scale each of the units per axis, and then at the end of the cut, run another macro to rescale back to the original units.
    Is g20/21/70/71 more complex than this?
    Rob
    Dec 2008
    3110
    Re: Uccnc - g20/g21 or g70/71
    I think the usage is to check that the control settings are in the correct units to suit the program
    ie G21 ( program is metric ) .....machine is set to inch.......result = "Error check machine/program units setting" , so program should fail to actually run
    You could use a different G code to scale the part, but....use caution.... it would also be scaling the tool sizes as well, RPM & feeds would be unchanged
    ie F2000. mm per min.... is a little fast on an inch setting
    Yes, it is. That's why Mach3 recommends using separate profiles for imperial and metric use, even though it supports G20/G21.
  1. UCcnc and PLASMA
    By vmax549 in forum UCCNC Control Software
    Last Post: 08-25-2018, 04:19 AM
  2. UCcnc CAM
    Last Post: 09-16-2016, 04:19 PM
  3. UCCNC Help
    By extsuba in forum UCCNC Control Software
    Last Post: 04-08-2016, 05:51 AM
  4. FED UP with UCCNC
    By jcarpenter2 in forum UCCNC Control Software
    Last Post: 03-10-2016, 11:24 PM
  5. Has anyone really used UCCNC?
    By greggv in forum UCCNC Control Software
    Last Post: 08-16-2015, 10:45 AM
