585,973 active members*
4,198 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Mori CL-20 with Fanuc MF-T8 controller not updating geometry.
Results 1 to 6 of 6
    Hello,
    I have a older Mori CL-20 lathe with the MF-T8 controller.
    My issue is I want to run multiple offsets for certain tools, for example T0515 so that I am using offset 15's geometry.
    But the issue is that I write it in the program and the controller says it is in offset 15 but it is still using offset 05 geometry.. does anyone know how to fix this issue?
    Thank you very much
    Feb 2006
    1792
    Re: Mori CL-20 with Fanuc MF-T8 controller not updating geometry.
    Set 5002#1 (LGN) = 0
    But I am not sure if this control uses the same parameter for this purpose. If not, look into the parameter manual under tool compensation section.
    Feb 2016
    11
    Hello
    Can Anyone send manual for this machine I lost All parameter ?Thank you
    Jan 2020
    9
    HELLO
    I have a older Mori CL-20 lathe with the Fanuc MF T8
    controller parameters i am an engineer of fanuc controller but my friend i need complete parameters of this machine can you help me please send me parameters and complete backup i shall be Thanksfull to you
    [email protected]
    Please send on this email
    Regards
    Jan 2020
    9
    Quote Originally Posted by abadade View Post
    Hello
    Hi do you have parameters of Mori seiki sl-20 with Fanuc MF-T8 Controller please if you have send me complete backup i shall be thanksfull to you my brother
    Thanks regards
    Dec 2015
    171
    I have pm me [email protected]
  1. Manual Needed for Mori Seiki MV 40 with Fanuc system 6M controller
    By dmeine in forum Machinery Manuals / Brochures
    Last Post: 12-22-2022, 02:44 AM
  2. Replies: 1
    Last Post: 04-19-2018, 03:33 PM
  3. Replies: 12
    Last Post: 05-01-2015, 04:14 PM
  4. Replies: 1
    Last Post: 10-01-2014, 05:10 AM
