586,000 active members*
5,031 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Injection Molding - Clamp force calc - Sliding blocks
Results 1 to 9 of 9
    Jan 2007
    I would like to know if anyone has a calculation or formula for working out the theoretical clamp force that a standard Injection Moulding machine would need to use when "Sliding Dies" or "Sliding Blocks" are used. I use a proven formula for straight forward, two plate tooling but when it comes to moving cores on angle pins I have a problem, I think that theoretically there should be little difference and the reason why I need high clamp force is because the heel block or the core block is not hard on. Any suggestions?
    Jan 2006
    62
    I believe the difference to be so slight that it's not worth woring about.
    Mark Reynaert, President Mark Mold and Engineering [email protected] http://markmold.com
    May 2006
    82
    Your locking blocks will transfer the pressure of the machine to the slide. The pins will not have any pressure on them. A designed interference will give sealoff.
    Jan 2007
    Sliding blocks
    Surely the gate position would have an effect? If the component was gated in a position where the melt pressure could open the blocks then this should be avoided. Are there any more thoughts on this?
    Jul 2006
    51
    The only thing that really should matter is the locking around the slide (sliding blocks?) It doesn't matter how much clamping pressure you put on the mold, if the heel flexes, it's useless. I usually like to have 3+ inches thick heel behind the slide to prevent that...(that is along with the locking angles on each side and a strait wall in front.)
    Lot of times Mold shop will leave couple of thao preload on the slide heel when spoting the seal off, just to make sure it is pushing forward HARD.
    May 2006
    82
    The shot pressure should not excede the clamping force of the machine.
    Nov 2006
    382
    Can you send me a sketch. Angles of the drivers and cams can change things. We normaly go 20 on the drivers and 15 on the angle pins. I figure 1000 psi on the square in. of area pushing on the pins. It is actually less than this but it is a good save number to use. 1.00 dia pin on a cam will see less than 750 lbs of push on its face. So a 20 degree driver has a roughly 4:1 mechanical advantage. So from only the pin the mold would see 187 lbs of force trying to push it open. A cylinder would see 750 lbs of push (not 750 psi). A cylinder with .5 square inches of cross-section would need 1500 psi to hold the pin closed. I have used air cylinders to hold .25 dia blind core pins in location. Send me a drawing I'll look it over. I have been doing this since 1981. Christ I'm grey when the hell did that happen...Oh well it was the last hair on my head anyway.
    Feb 2007
    498
    what formula do you use?wall stock and material type change the factor to use,thinner walls and tougher flowing material need higher clamp pressure,molding surface area parralel to the platen is all that matter,vertical walls dont add tonage,but you do need to account for them on mold design for safe opperation with out failures,on slides with larger areas i usely design
    and angle on the lock oppisite the slide to counter lock the back against the ejector(or movable)side of the mold,a ledge,or L shaped lock give more strenght to the lock
    Jun 2007
    Clamp Slide Blocks. calculations at www.injecneering.com
    Martin
    I realize this is quite a late answer but is going to be very helpful.
    There is a web page: http://www.injecneering.com that we have created to give free access to applications for injection molding engineering. One of the five applications offered (Machine Selector) calculates the clamping force a tool needs. It does consider the effect of slides in the clamp force by calculating the force component in the platens' opening direction (see first picture below). It also considers the frictional force (reduces the clamp force). I agree with MrMold's comment that most of the times the effect of the slides in the clamp force is negligible. However, I have ran into tools where that is not the case as the slides' areas are bigger than the projected area (See second picture). I also like to always include it anyways just for the sake of accuracy.
    Hope it helps
    Mauricio Benavides
    Attached Thumbnails Attached Thumbnails clamp force slide.jpg   clamp force calculation.jpg
  1. Injection Molding Help
    By cjs83 in forum Moldmaking
    Last Post: 11-09-2009, 08:38 AM
  2. Solutions to Plastics Injection Molding & Die Casting in China
    By zhumingjia in forum News Announcements
    Last Post: 10-11-2007, 03:51 AM
  3. General Injection Molding Terms?
    By Mech_E_Travis in forum Moldmaking
    Last Post: 01-02-2007, 10:48 PM
  4. Resolution calc help needed for Mach2
    By Moondog in forum Mach Software (ArtSoft software)
    Last Post: 02-01-2005, 01:55 PM
  5. screwless vice clamp blocks
    By JFettig in forum Benchtop Machines
    Last Post: 04-16-2004, 01:03 PM
