hello guys,
I am working a mazak 200 IV with a renishaw tool probe. I am using the tool probe to do tool breakage after each operation on drills and taps etc. It is also synced with a robot although i dont think that is the issue. Every time the program runs from the start it gets to the tool breakage where it calls a sub program which renishaw put in the mazaks memory and it alarms out with 846 DESIGNATED NUMBER NOT FOUND in the error book it says the designated variables number is larger than the maximum variables number permitted by the specifications. I do not know how to alter this if it is the problem so any help in this would be greatly appreciated. I have also added a sub program before the tool checking to check a bore, update the offset and recut the bore I wouldnt think this would affect it although i may be wrong.
Any pointers or information would be greatly appreciated.
J
