585,880 active members*
6,672 visitors online*
Page 1 of 2 12
Results 1 to 20 of 33
    Oct 2007
    446
    Question Anyone use down cut bits for wood cutting...
    I'm mainly cutting wood on my machine and was wondering if anyone uses downcut bits on their machine....I hate sanding parts with a passion and wondering if down cut is a good way to go? or would they get too hot on wood??
    Re: Anyone use down cut bits for wood cutting...
    I use downcut bits almost exclusively for cutting hardwoods.
    Oct 2007
    446
    and how is the result with those? i'm assuming little to no sanding required..?
    Where is a good source to get some...i ordered all of my tools from shars.com, but they have nothing for down cut...
    Jan 2013
    39
    Nice questions. I really need also a good supplier.
    Στάλθηκε από το Elephone P8000 μου χρησιμοποιώντας Tapatalk
    Depends on what your doing, and what type of wood. Also depends on how well the parts are held down, and how rigid your machine is.
    I sand everything that I do, but what I do requires it.
    Most of my tools comes from Vortex Tool: Solid Carbide Router Bits and Compression Spirals for woodworking, plastics and non-ferrous industries. or Onsrud.
    Jun 2014
    777
    Downcut spiral for pocketing, rebates etc compression spiral for contouring. Upcut spiral ball nose would be the only upcut bit I would use personally, upcut endmill spirals have little or no use for wood imo.
    They are good for cutting vertically mounted boards, mortise and tenons, and box joints.
    Jun 2014
    777
    Do you mean on the side grain? yeah I suppose if the mortise was very deep and small in size. You will still get furring I'd imagine so if it's not massively deep would a dc spiral no be better.
    I must admit I haven't done any routing with end into side grain.
    Oct 2007
    446
    Quote Originally Posted by Jon.N.CNC View Post
    ...great...all of mine are upcut...ha...learning the hardway again..
    still haven't found a good source for downcut bits...they seem to be the minority...
    Downcut bits are very common woodworking tools. You won't find them at places like Shars, that sell tooling for metalworking.
    Depends on the use of the mortise, and the depth. For a shallow mortise where the edge is visible, I'd use a downcut. For anything deep or if the edges won't be seen, I'd use an upcut..
    These were cut with an upcut bit.
    Sep 2009
    1856
    if you cut malamene up cut, down cut compression spiral bits work well and don't chip the edges. as ger21 says it all depends on what you cut, trial and error. tools2day sale all sorts of bits they have the good stuff and free shipping, there recommended settings are close and what type of material the cutters works well with is correct.
    but if in dealt ask ger21
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Oct 2007
    446
    yah not a whole lots of options out there for down cut bits...at least in canada..lowes has a 1/4. and only found one place in the states so far that ship USPS...other wise i dont order from the states...couriers cost an arm and leg to get anything across the border....
    Jun 2014
    777
    Quote Originally Posted by airbrush View Post
    Vortex are the best us bits I know of. Should be easy to get in Canada I would have thought.
    Jun 2014
    777
    They are very clean edges. That's interesting. You must have quite a z clearance there. 5axis?
    They are sample pieces, only 3" long. Done on my DIY machine.
    http://www.cnczone.com/forums/cnc-wo...st-router.html
    Royce AYR is a Canadian manufacturer of high quality router bits.
    R57-322 | Royce//Ayr Cutting Tools
    Here's a list of their distributors in Canada.
    https://www.google.com/maps/d/viewer...6KrskEbVSebEus
    May 2005
    1662
    Yonico down cut endmills are available on Amazon.ca.
    I've only begun testing this brand but so far so good.
    Btw it looks like the posties are going on strike soon .
    Anyone who says "It only goes together one way" has no imagination.
    The box joint pics I posted earlier were done with a Yonico bit from Amazon.
    Oct 2007
    446
    will probably pick up that 1/4 yoniko...i would like an 1/8' down cut as well with an 1/8 shank...doesnt seem to exist
Page 1 of 2 12
  1. Replies: 0
    Last Post: 08-31-2014, 06:38 PM
  2. Replies: 0
    Last Post: 07-23-2012, 09:26 AM
  3. Wood cutting bits
    By alk-3 in forum CNC Tooling
    Last Post: 01-04-2012, 02:50 AM
  4. Advice on cutting bits for wood please?
    By Ranscon in forum WoodWorking Topics
    Last Post: 03-21-2009, 03:21 AM
  5. Cutting ali on wood router - low rpms breaks bits. Why?
    By lsteele in forum DIY CNC Router Table Machines
    Last Post: 01-06-2009, 10:49 PM
