585,981 active members*
4,288 visitors online*
IndustryArena Forum > CAM Software > Surfcam > multiple work offsets
    Oct 2006
    99
    Been looking to do use multiple offsets such as a g54 and g55 on seperate vises. Hints would be much appreciated.
    Thx
    Feb 2006
    49
    Hi
    press start, programs, surfcam group, surfcam tools, "post menu wizard"
    press next until two windows appear,
    on the left window scroll down until you see post that has sub in the name, there are sub posts for fadal, fanuc,
    choose one and proceed until done.
    This will add a post that when used will automatically put out sub routines for all your tools. You may need to edit the code for machine specific rules but its a start.
    Jan 2007
    5
    Smile
    Quote Originally Posted by rbest27 View Post
    Thx
    It depends on what you wantto do. You can use Cveiws on all sides of the part then run a differant side in each vice.
    In the tools, Options, NC Defaults, Work Offset. Check the associativity box
    When Creating a CVeiw, be sure to add the work offset and your work offsets will automaticaly be defaulted.
    Next your post must be properly configured to detect a work offset change
    UPONWORK
    G[Work] X[H] Y[V]
    END
    This is the way it should be done for multipule sides of a part or when indexing
  1. Replies: 12
    Last Post: 04-05-2019, 10:21 PM
  2. Bridgeport VMC 500 XP1 - Work Offsets
    By cadcamjohn in forum Bridgeport / Hardinge Mills
    Last Post: 05-03-2006, 10:31 PM
  3. work offsets
    By 5axisdan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2005, 04:17 PM
  4. Work Offsets
    By new2cnc in forum Mastercam
    Last Post: 04-30-2005, 04:04 PM
  5. Setting Work & Tool offsets
    By Shizzlemah in forum Fadal
    Last Post: 04-16-2005, 06:04 PM
