586,024 active members*
3,810 visitors online*
Results 1 to 6 of 6
    colchester cnc 2000l parameter
    does anyone have the full parameter files backed up. I would be thankfull if anyone could e mail them to me.
    thank you all
    May 2016
    526
    Re: colchester cnc 2000l parameter
    111
    Dec 2008
    3109
    use the "Search" feature.... LINK
    wiring diagram does anyone has the wiring diagram as well
    Superman I did already. two problems left spindle not working and I have an 8 staion duplamatic .. in your file I just found 4 duplamatic parameter and 8 staion sauter.
    May 2016
    526
    Have you initialised the spindle on the rear of the machine, on some of these there was a separate button to bring on the spindle as for the duplomatic that is just a diagnostic turn on
    I started working on the machine from the point the monitor did nt even turn on. with a lot of problems starting from memory loss till many boards had to be cleaned. had problem with door closed switch and many more. till now never had a wiring diagram nor the parameter from superman. was later able to enable the plc view. so at least could work my way through that. my problems now are the turret and the spindle not working.
    else i believe everything is working. In supermans parameter 8120 parameters where missing where motor is and direction are described. till i changed them i got 417 427 servo error
  1. Colchester 2000L
    By bertcnc in forum Colchester Tornado lathes
    Last Post: 06-25-2020, 07:40 AM
  2. colchester 2000l CNC not ready alarm
    By Hakam in forum Fanuc
    Last Post: 02-09-2017, 05:50 AM
  3. Colchester 2000L APC 310 and 320 Alarm
    By rjhzxc in forum Colchester Tornado lathes
    Last Post: 04-23-2014, 02:38 PM
  4. Colchester 2000L Fanuc OT
    By davee1987 in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2013, 10:26 PM
  5. Need Parameters For Colchester 2000L CNC
    By Hakam in forum Colchester Tornado lathes
    Last Post: 10-27-2012, 02:46 PM
