How do you know how to setup the simulator to test run your parts? I'm having mixed results when I try to use it. Here's a simple file for demonstration purposes... sometimes I'll get it just about right, but more often than not the tool cuts the surface at weird places.
I guess my question is, how do I set up simulate to display this file correctly? Say the stock is X=4,Y=2 and it's .5 in Z with a .1 depth of cut. File is in inches and the post processor is for Mach3.
On simulating your 'testspiral' program it looks like the tool passes through your letter 'S' when moving to do the small pockets.
You may need to alter Tool Postion Z (Rapid Plane) figure under Tool Depth Settings.
On checking your code there is no change of Z from start to finish.
Thanx gents. I'm having a bit of a trying transition to Bobcad... I'm not used to not defining my stock more than anything I guess. It's really throwing me off for part setup. Any tips?
A few tips. Some are personal preference.
1) I like to draw a block or cube that represents the Material to be Machined.
2) When Milling always set X0 Y0 to the Hard Jaw and Banking Point.
3) Be mindful of what tools you want to use as not to Machine Your Vise.
4) Always use a Common Z0 for all your projects. In other words Z0 should be a Clean Face on the top of your Material. All Z moves there after should be Z- (Z Minus)
Here is an example
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
There we go - good tip. I think that'll work for me. On your material representation - is it a solid model? I mean, did you extrude curves to create the box? Then just put it on another layer?
Also, did you create your model in Bobcad?
No and No
The Model is in Mike Mattera's Tutorials for MCV9 that I am learning at a friends shop.
The Box I created using the Rectangle Function in BCC V21. I usually start there to get some rough geometry.
These were done in BCC V20.
BCC can be great if you really get to know it well. Been a user since V17.
Toby D.
Schwarzwald
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
