585,877 active members*
3,488 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 930 cpu interrupt when transferring pc -> cnc via rs232
    Jun 2008
    113
    This has happened twice in a short period of time in the exact same situation. When I send a program from PC to the CNC via RS232, the file transfer fails and the control (Fanuc 18i-T) goes into a 930 CPU Interrupt error screen. Any ideas what is causing this? After restarting the control and clearing memory, re-transferring the same program succeeds. Memory failing?
    Oct 2014
    137
    Re: 930 cpu interrupt when transferring pc -> cnc via rs232
    If you use for link the office computer that reason of this error can be hindrance voltage from computer. The capacitive filter of the hindrances PC creates the variable voltage to contacts of RS232C connecting. The Interfaces RS232C have not a galvanic uncoupling. Hereinafter it can destroy your interfaces.
    Jun 2008
    113
    I will replace the cable and check the voltages. The cable could have taken some damage in our hostile environment. Thanks for the reply.
    Jul 2022
    i had faced the same error msg but when i connect the CNC Machine to an ethernet cable and im still dont know whats the problem exactly
  1. FANUC O-T alarm 930 cpu interrupt
    By chatree_w in forum Fanuc
    Last Post: 01-12-2023, 09:30 AM
  2. Feed interrupt needed, I think??
    By thedoctor in forum DNC Problems and Solutions
    Last Post: 07-17-2008, 02:03 PM
  3. No Interrupt on vf2 2000
    By tecko in forum Haas Mills
    Last Post: 01-26-2008, 01:59 AM
  4. E-stop, Interrupt The 110v Ac Or 28v Dc?
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 02-06-2007, 03:49 PM
