585,997 active members*
5,068 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Use Joystick to control 3 Axes.
Page 2 of 2 12
Results 21 to 38 of 38
  1. #21
    Mar 2006
    759
    NGinuity, you need to hurry up. If you don't hurry, I might build it myself
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
  2. #22
    Sep 2006
    245
    My design plugs directly into the parallel input port of the HobbyCNC stepper controller. It is really handy for testing my router before I move a PC out to the garage. I doubt I will ever use it after I have a computer nearby with Mach 3 installed.
  3. #23
    Dec 2006
    40
    Quote Originally Posted by massajamesb View Post
    If you do, I will give you 5 dollars for it :-)
  4. #24
    Dec 2006
    204
    STEVE 323 Are you going to sell yours after you get your system going?
    Dan
  5. #25
    Dec 2006
    40
    Quote Originally Posted by steve323 View Post
    Do you really suspect that putting it inline of the computer will cause it to miss steps? Could you possibly mitigate that risk by using blocking diodes so the parallel signals from each device don't interfere with each other? You could also build some sort of "lock out" option that would prevent output from the joystick if there was data coming from the computer. I only ask that because I really have my heart set on running the panel inline.
  6. #26
    Mar 2006
    759
    Quote Originally Posted by NGinuity View Post
    SOLD!
    You wouldn't be offering me that if you knew how much R&D I have in my design.
    I think somewhere around 1.32 USD would be fair....
    -RedGreen show.
  7. #27
    Dec 2006
    40
    SOLD!
    Perhaps I could persuade you with a count of 6 adult beverages next time I am at the shop? :-D
  8. #28
    Mar 2006
    759
    And yet again, SOLD!
    :cheers:
    -RedGreen show.
  9. #29
    Dec 2006
    40
    :cheers:
    That joystick might just start working on it's own after enough beer! LOL
  10. #30
    Mar 2006
    759
    Ah, you figured out my design. It's copywritten, so I can't provide you with a schematic.
    -RedGreen show.
  11. #31
    Dec 2006
    40
    Great. Thanks a lot...now I have to clean all of the sweet tea off of my keyboard I just spit out when I read that :-D
  12. #32
    Jul 2005
    2415
    Let you do what, exactly?
    Just about anything you want. Here is a 28 function Hand Controller with a Jog Stick (proportional jog speeds with two ranges and a single step mode and the XY or ZA select button. In addition you can contol things like referencing 3 or 4 axis, zero the DRO's (reset workpiece zero) RUN , STOP Feedhold, Feedrate overrides, Spindle speed overrides, Spindle on/off etc ,etc.
    What makes it all work is the ability to write Plug-in programs for MACH using the SDK.
  13. #33
    Dec 2006
    40
    What language is the SDK? The design I am working on would involve a DRO LCD display that is on the machine itself. Is that what this does too?
  14. #34
    Apr 2005
    3634
    Check this out from "hoss2006" (here on the zone), joystick, jog buttons, DRO, everything!
    He shows how he built this on his website.
    http://www.hossmachine.com/projects_...#control panel
    And another thread he started:
    http://www.cnczone.com/forums/showthread.php?t=30385
    His website says he used Keygrabber from Mach3, to program the buttons.
  15. #35
    Dec 2006
    40
    Actually, i am not looking for something quite that robust, but I can definitely see some similar ideas I have.
  16. #36
    Sep 2006
    245
    No, I plan to keep it for testing my future CNC milling machine. I will probably need it to test my CNC lathe after that. I have 2 small kids, so this plan will take many years to complete.
  17. #37
    Sep 2006
    245
    There seems to be many simpler options of using a secondary USB keypad to send control signals directly to Mach. This would avoid the need to intercept the parallel port data path. Of course, this only works after you have installed Mach and have a computer in your workshop.
    My design only has a parallel output port that is sent directly to the HobbyCNC board. I thought about adding an input port, but decided to keep my design "quick and dirty" so it would have a chance of getting completed.
  18. #38
    Jul 2005
    2415
    Installing a second parallel port for MACH costs less than 20 bucks and takes about 10 minutes (on a bad day).
    Tom Caudle
    www.CandCNC.com
Page 2 of 2 12
  1. 21i TB joystick....
    By patrickb in forum Fanuc
    Last Post: 07-13-2006, 11:20 AM
  2. joystick
    By phe259 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-27-2006, 07:37 AM
  3. Adding a Joystick.
    By on7tim7 in forum Mach Mill
    Last Post: 01-10-2006, 08:33 PM
  4. Standalone Joystick Stepper Control
    By kochevnik in forum CNC Machine Related Electronics
    Last Post: 08-28-2005, 11:22 PM
  5. Joystick Control
    By Sanghera in forum DIY CNC Router Table Machines
    Last Post: 06-16-2004, 05:39 AM
