585,712 active members*
4,302 visitors online*
Results 1 to 2 of 2
    Mar 2013
    Maho MH500C Spindle problem
    I have just bought a used MAHO MH500C. I have a problem with the spindle. The machine didnt start when I press the start button. In the LED error screen there is the code 30. I have the electrical drawings of the machine and I checked the cables. This error is caused by Indramat TRK6 spindle drive. I checked also the TRK6 and I have found that the problem is d1 relay that when it is triggered the green LED "BB" goes on. The relay is ok but I cant found what is the problem. Do you have any suggestions or how can I find the manual for Indramat TRK6-4U?
    Mar 2013
    Re: Maho MH500C Spindle problem
    Still I havent found a solution. At the spindle drive at the upper left corner there are some red Leds. I think these Leds are for errors. There is a PUE Led that is on all the time. Do anyone know what PUE stands for?
  1. problem with keyboard maho GR 400 / 200 CNC 432.
    By djebaili in forum DNC Problems and Solutions
    Last Post: 12-12-2016, 11:12 PM
  2. Deckel maho mh500c
    By gaherne in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-20-2010, 12:38 PM
  3. Maho 600E2 setup problem
    By sts in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-12-2010, 12:55 PM
  4. Philips 432 diagnostics test? (MAHO MH500C)
    By AndreasL in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-08-2009, 02:40 PM
  5. MAHO-PHILIPS 432 M60 and G23 problem
    By micktat in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-03-2009, 11:10 PM
