Getting my first DIY machine running. everything is great except the output #1 for spindle relay (actually using for turning torch on/off)
Not sure if this is the right section - but here it goes!
Using Mach3 with the TB6560 4 axis BoB. Trying to use the m3 command to turn on the hypertherm plasma cutter. We have a 36V 30A relay in order to trigger the plasma cutter.
When I plug the multimeter into the ground & pin on the breakoutboard (output #1, pin1, port1) i get a steady 36 Volts using the m3 command. However, I only get 0.53mA amperage when activating the spindle on/of, which is nowhere near enough to trigger the relay... Do I need an amp to get this amperage up? or is there a way to increase the ampere power to the breakout board via mach3?
Thanks for the help!
