584,837 active members*
5,242 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > GrblGru: Free CAM and 3D-Simulation for mills and lathes
Page 17 of 38 7151617181927
Results 321 to 340 of 743
  1. #321
    May 2016
    329
    Re: GrblGru: Free CAM and 3D-Simulation for mills and lathes
    Sorry for the late answer, but I was on vacation.
    @jeff1000
    Hm, theoretically this would be possible. But so far, all machines are always equipped with only one tool. I think the effort would be huge.
    @Daggersuk
    Unfortunately my probe is not operational at the moment.
    Therefore I could only test the simulation with an STL object. But that worked fine.
    Do you have the problems only during real measurement or already during simulation ?
    Please check again if the 'Lift' value is big enough.
    After a measurement the probe has to lift so far that it doesn't touch the workpiece anymore.
  2. #322
    Mar 2018
    6
    Thanks for the reply.
    I am only using simulation mode.
    Using fresh 3.49 install and “cobra” machine & “Plane_10”, all works as it should. All scan points & X,Y,Z points correct.
    If i change to machine to “1310” and use the “Plane_10” i only get the first row of scan point displayed. When i look at the displayed coordinates all “X” rows are shown but the “Y” and “Z” are repeated values from the first row. You can watch the probe ball bounce off of the wedge on the first row then on the second and subsequent rows gradually pass through the wedge.
    The lift value makes no difference, set to very high as a test, “100”, made no difference, probe ball still passes through the wedge.
    I would like to use the 1310 model as i have a machine on its way from china.
  3. #323
    May 2016
    329
    @Daggersuk
    Just a short info. You are right.There is a bug in all machines where the workpiece will move.
    It is interesting that a single measurement works. I will contact you as soon as I have found something.
  4. #324
    May 2016
    329
    There is a new beta version V3.49.8 on my website
    With this version the scanning should work again.
    Thanks again for your help
  5. #325
    Mar 2018
    6
    Thanks for software update.
    Probe working great and coordinates correct.
    All the best from the UK, stay safe.
  6. #326
    May 2016
    329
    Beta notes V3.49.9
    On my website is a new beta version V3.49.9. It contains the first attempt to make measuring on the lathe available again.
    I have made a short video about it. It shows how to measure an STL object virtually. The calculated GCode can also be sent to the controller.
    Unfortunately my probe is not working at the moment. Therefore I could not make any tests in practice.
    Have fun with GrblGru
    https://www.youtube.com/watch?v=vmuK...ature=youtu.be
  7. #327
    May 2016
    329
    GrblGru @Linux ?
    I have been asked many times if GrblGru is also available for Linux. Until now I always had to deny this.
    But now a clever user has found a way to run GrblGru on "Wine" under Linux.
    According to him it is still possible to improve the process.
    Since I have no experience with Linux, I can only pass on the instruction on my website at the moment. (See https://www.grblgru.com/)
    I would be very happy if the Linux gurus of this forum would take a look at it.
    Necessary information and also changes for further improvements I will gladly provide.
  8. #328
    May 2016
    329
    Just a short information. On my website there is a beta version V3.49.14 with the new operation mode "Tangential Blade".
    https://www.youtube.com/watch?v=oNQF...ature=youtu.be
  9. #329
    May 2016
    329
    @JOKaija
    please have a look at the new beta version V3.49.15 on my website.
    I have reworked the lathe operation once again. Thereby g52 Y0 was replaced by G10 L20 p1 y0.
    You can also edit now the calculated GCode if something does not work.
  10. #330
    Nov 2020
    Quote Originally Posted by GrblGru View Post
    Using O-Codes needs a special command at the beginning of the Gcode.
    This command is 'g#2g'. This activates the great library g#2g, which is a subset of LinuxCNC.
    For details please see: https://github.com/nrsoft/gsharp
    For example this should works:
    g#2g ; Important to activate the lib !!!
    #1 = 20
    #2 = 2
    g91 g1 f500
    o100 repeat [3]
    x#1
    y#2
    x-#1
    y#2
    o100 endrepeat
    I have to admit that the special command 'g#2g' came into the program later, and it's nowhere described.
    Sorry for that.
    Let me point you to the possibility to use the GrblGru macros (toolbar on the right side) for quick checking the O-Code syntax.
    For using the macro and the O-codes see link below.
    https://youtu.be/5UIVro7R7AU
    Hi. i am new here with CNC machine. i downloaded your software that command you mentioned g#2g is not working. will you help me how i use this in your software with GRBL
  11. #331
    Jun 2007
    33
    Hello GrblGru
    Whenever I appear it is to report a Bug.
    When importing or exporting the DXF file, an element called “bulge” with code 42 is missing.
    Attached DXF reference file.
    The math expression is:
    bulge = tan (sweep angle / 4)
    bulge = heigth / (length / 2)
    See screenshot of CamBam.
    See screenshot of Visual Studio 2019.
    Armando
    Attached Files Attached Files
  12. #332
    May 2016
    329
    @ahmed832
    The video is unfortunately already very old. In the meantime I have continued to work on the macros.
    So I replaced the original library of Linux CNC with my own functions. The reason was that the library did not run under WinXP.
    Therefore the command 'g#2g' is no longer needed
    Please have a look at the current video about macros.
    https://www.youtube.com/watch?v=Awdb...ature=youtu.be
    Let me know if you have any questions afterwards.
    @Armando
    thanks for your feedback.
    But I have not yet understood the problem.
    The screenshots are very indistinct. Unfortunately I cannot see anything on them.
    Could you please describe in detail what is not working ?
    In which program does the error occur ? Do you import a file to GrblGru or export a file to CamBam? Is there an error message ?
    Can you provide me with a DXF file that does not work ?
  13. #333
    Jun 2007
    33
    Hi GrblGru
    Thanks for the quick reply, see attached the DXF file as an example.
    In the internal structure of the DXF files there are polylines with bulge code 42.
    A circle can be converted to a polyline with bulges.
    Applying programming mathematics is
    bulge = Math.Tan (Sweep / 180.0 * Math.PI / 4.0);
    See image below.
  14. #334
    May 2016
    329
    Ah, now I understand you.
    But I have to tell you that I cannot interpret the complete DXF command set. I do not use a library but programmed everything by hand.
    You can see from the amount of the manuals that there are countless commands, some of which are only available for historical reasons. There are also some commands with mathematically very sophisticated functions, whose realization would require a lot of work and time.
    The DXF import is only a small subitem in my program and I hope you understand that I want to concentrate on the most important things first. But I will put this item on my todo list.
    Thanks for your help
  15. #335
    Jun 2007
    33
    Dear friend GrblGru,
    It doesn't matter which version of DXF.
    In the file “autocad_2012_pdf_dxf-reference_enu.pdf”, attached, look for the word “bulge”.
    See attached a part of the source code.
    See some references:
    https://cambamcnc.com/forum/index.ph...49830#msg49830
    https://cambamcnc.com/forum/index.ph...64299#msg64299
  16. #336
    Apr 2014
    215
    I was wondering if it was possible to do an internal boring operation? (for lathe turning)
    Many thanks, great program (I've only dabbled with it from time to time).
  17. #337
    May 2016
    329
    @Armando
    I heard you. But as I said before, I have it on the list, but there are more important issues at the moment.
    @robertspark
    Yes, there's a trick to it. You just have to clamp your lathe tool turned 180° around its lengthwise axis.
    Then you work on the rear edge of the workpiece and you can use the normal automatic program.
  18. #338
    Jun 2007
    33
    @GrblGru
    My goal was to help you, the software is yours!
    I installed version 3.49.19 and didn't like what I saw.
    I lost interest...
    Armando
  19. #339
    May 2016
    329
    @Armando
    It is very unfortunate that you have lost interest in GrblGru.
    But of course I accept your decision and would like to thank you again for your help in the past.
    Wish you a good time.
  20. #340
    Hello,
    how can I send you 'Language_french.txt' (112 kb) for 'GrblGru-3.49' ?
    Good day.
  1. Affordable CNC Mills and Lathes
    By cweber in forum Uncategorised MetalWorking Machines
    Last Post: 04-20-2013, 10:44 AM
  2. D&M Lathes, Mills, etc.
    By boatlover in forum Benchtop Machines
    Last Post: 04-25-2008, 02:39 AM
  3. Birmingham Mills and Lathes
    By smilenbseen in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2007, 01:19 AM
  4. Birmingham Mills and Lathes
    By smilenbseen in forum Vertical Mill, Lathe Project Log
    Last Post: 01-02-2007, 01:42 AM
  5. Darn near FREE LATHES!!!! - 2 lathes, gotta go NOW!
    By mxtras in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2006, 07:43 PM
