585,925 active members*
3,582 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > GrblGru: Free CAM and 3D-Simulation for mills and lathes
Page 7 of 38 5678917
Results 121 to 140 of 750
  1. #121
    Jul 2018
    Re: GrblGru: Free CAM and 3D-Simulation for mills and lathes
    I have a question. Is it possible to change the coordinate system of the lathe from "X-Y" to "X-Z" in GrblGru? My lathe understands only two coordinates "X-Z". And the coordinate "Z" is the axis of rotation of the spindle while "X" is the feed of the tool.
  2. #122
    Oct 2006
    31
    Can anyone advise why I can't run the simulator on following file:
    https://drive.google.com/file/d/1ArQ...ew?usp=sharing
    Using GrblGru V3.28.1
    I'm getting a lot of unhandled exceptions.
  3. #123
    May 2016
    332
    @gryzel
    Right now, I'm in the process of changing the lathe coordinate system.
    Give me a little more time, please. I hope to finish it this week.
    @swisscheese
    I read your file and for me everything looks very good. The simulation is running and I don't get any error messages either.
    It would be very helpful for me if you would open the two controller windows and run the simulation in single step mode. (Toolbar button "Single")
    Can you please send me screenshots of the error messages and the display in the controller window ? So I can see which command causes an error.
    Please also take a screenshot of your self-defined tool "187 EM". What is the diameter of the cutter?
    Do you only have this problems with this file, or do you have the errors with every file?
  4. #124
    Oct 2006
    31
    187 tool: Milling, Endmill, 6,35, 0, 10, 2, 2, Yes
    I never got anything to work - just learning it.
    As soon as I open the project file I get:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at GrblGru.Form1.GetZigZagPath(xPath xPath, xJobMilling xBaseJob, Double diameter)
    at GrblGru.Form1.DoJobPocket(xJobMilling xJob, ToolMilling xTool)
    at GrblGru.Form1.CreateGCodeForMilling()
    at GrblGru.Form1.CreateGcode()
    at GrblGru.Form1.LoadProject(String FileName)
    at GrblGru.Form1.loadProjectToolStripMenuItem_Click(O bject sender, EventArgs e)
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
    at System.Windows.Forms.ToolStripMenuItem.OnClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
    at System.Windows.Forms.ToolStripDropDown.OnMouseUp(M ouseEventArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.ToolStripDropDown.WndProc(Mes sage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3110.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    GrblGru
    Assembly Version: 3.28.1.0
    Win32 Version: 3.28.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/toe/GrblGru/GrblGru.exe
    Win32 Version: 4.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    toe.Lib
    Assembly Version: 1.3.0.0
    Win32 Version: 1.3.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/toe/GrblGru/toe.Lib.DLL
    toe.Cad
    Assembly Version: 11.3.0.0
    Win32 Version: 11.3.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/toe/GrblGru/toe.Cad.DLL
    toe.Props
    Assembly Version: 1.0.6732.37059
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/toe/GrblGru/toe.Props.DLL
    toe.Tree
    Assembly Version: 1.9.0.0
    Win32 Version: 1.9.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/toe/GrblGru/toe.Tree.DLL
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Design
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
    System.Drawing.Design
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
    toe.Clip
    Assembly Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/toe/GrblGru/toe.Clip.DLL
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  5. #125
    May 2016
    332
    @swisscheese
    That's strange.
    Can you please select another milling cutter in all 3 jobs for testing (e.g. "end mill 3.175")
    If this doesn't work either, please load the DXF example "MotorPlate.dxf" and create a simple job (e.g. "Slot Plywood") for the layer "center milling".
    Make sure that you have selected "Controller" = "Simulation". Press the "Origin" button.
    Select "High speed simulation" and press the green start button.
    Is the simulation now running without errors?
  6. #126
    Oct 2006
    31
    With your suggestion I found the problem. I had my tool setup wrong. I had number of flutes at 0 and width at 2 - should be 2 flutes and 0 width. Suggest to improve defensive code / error reporting.
  7. #127
    Oct 2006
    31
    Now I have another problem. Grbl Panel stops in the middle of the GrblGru program for no reason. I found that if I delete exclamation marks (!) in comments that GrblGru generates it resolves the problem but doing that is cumbersome. Please advise.
    Also, please allow to toggle items on and off during multiple selection - this is standard UI. Otherwise it is very difficult.
  8. #128
    May 2016
    332
    @gryzel
    I've uploaded a new beta version V3.28.6. bit.ly/2xCD7Nd_GrblGru_Beta
    This contains the new standardized XZ coordinate system for the lathe.
    If you want, you can try it now.
    I'll try to make some documentation, but this will take a time.
    Please note that you must first enter the diameter on which you start in the new entry "Start diameter".
    Then after loading a DXF file you can add a job for the toolpath in you drawing.
    Everything now works in exactly the same way as when milling.
    @swisscheese
    Thank you for your feedback. Even if it doesn't run 100% yet, I'm glad that the first error was found.
    Sorry, can you please explain again what you mean by "toggle items on and off during multiple selection". I don't understand.
    And can you send the file that causes the error with the "!". I'm sure we'll find that, too.
  9. #129
    Nov 2016
    7
    Quote Originally Posted by GrblGru View Post
    @gryzel
    Hi GrblGru,
    Saw your posts that you have been working on the X/Z lathe system and uploaded a beta version.
    That's really cool news and I'll try to play with it in the next few days to run my son's Unimat Lathe.
    Thanks for all your hard work and sharing your talents with all of us !
    Jay Perez
  10. #130
    Oct 2006
    31
    @GrblGru
    Go into Windows file manager; hold down the Ctrl key; click on various files - some more than once. That is how mutiple selection is supposed to work.
    Also, why is the U notch in the upper right part not fully machined in this file:
    https://drive.google.com/file/d/1FqD...ew?usp=sharing
  11. #131
    Jul 2018
    @GrblGru
    Thank you for beta. Still buggy, but usable. Hope you polish your program. If you need bug reports I will provide you with some. Let me know.
  12. #132
    May 2016
    332
    @swisscheese
    Thank you for your explanation on the subject of 'multiple selection'.
    I assume you are talking about selecting a toolpath from the drawings list. You're right. It's a standard interface, but it's work, that has to be done.
    I'll do my best. In the meantime I would like to point out the possibility to select the paths directly in the graphic window. I think this is more comfortable.
    You can select one or more paths with a window (left mouse button) or one path with ALT + left mouse button.
    A click with the right mouse button opens a context menu with which you can also hide or delete paths. Here you can also create a job directly.
    I checked your file and can't find any errors.
    Also the PreView looks good to me. See attached pics. Can you please describe once again what's not okay ?
    @gryzel
    Yes, of course. Bug reports are welcome.
  13. #133
    Oct 2006
    31
    Thanks - now I see multiple selection on the drawing works correctly - that will work for me.
    I figured out the toolpath problem - I had my 3/16 EM with diam 6.35mm which is 1/4"! My bad.
    My biggest remaining gripe is having to manually remove "!" characters after every g-code export.
  14. #134
    May 2016
    332
    That '!' is the stop command for Grbl, but it is written in a comment and "Grbl Panel" is not allowed to stop there.
    However. I have uploaded to you a new beta version V3.28.9. I found one place in it and removed the '!'.
    If you find a text with '!' at other places, you can find in the directory C:\ProgramData\GrblGru your language file
    where you can change the text. (For English text = Language_English.txt)
    Finally, the note that you can also use GrblGru to transfer the GCode.
    All you have to do is select your controller and your Com port in the "Configuration" group box and press the Start button.
    You can then check the transmission in the two controller windows. See attached pic.
    Another advantage is that GrblGru then uses Grbl's feedback to animate the 3D model of your machine. So the 3D model moves synchronously to your 'real' machine.
    If you use "Grbl Panel" because it has a function that GrblGru does not have, please let me know.
  15. #135
    Oct 2006
    31
    I found some "!" in the language file but mostly in comments - did not seem like removing them would help. Is there a particular line?
    Where do I get V3.28.9 ?
    As for using GrblGru intead of GrblPanel, the later has jog increment settings, GRBL settings, special goto positions, pause, resume, manual G commands (MDI) - that's what I use.
  16. #136
    May 2016
    332
    You can always find the current beta version at bit.ly/2xCD7Nd_GrblGru_Beta.
    and the last released Version at bit.ly/2xF1KJ8_GrblGru_Release
    If you still have problems with the '!' please send me the GCode file so I can see what's going on.
    I hope I don't talk like a salesman, but:
    - jog mode ist available, also with remote control
    https://youtu.be/HSsUbzgWuzo
    - GRBL settings can edit in the controller window
    - Special goto positions and functions can be realised with simple macros
    (The macro toolbar must be enabled on the settings page)
    https://youtu.be/5UIVro7R7AU
    But GrblPanel is certainly a very good program and I prefer to use programs I know well.
  17. #137
    May 2017
    25
    Any hope of adding the g20/g21 (Inch/Metric) functionality? That seems to really be the only thing missing here!
  18. #138
    Oct 2006
    31
    @GrblGru
    Decided to try using GrblGru instead of GrblPanel but jogging gives error "Grbl error 15 ... Jog target exceeds machine travel".
  19. #139
    May 2016
    332
    @The_Dream_shed
    Thanks. Of course I have it on my todo list.
    But right now, I just can't find the time. But I promise I won't forget it.
    @swisscheese
    It works for me without errors and I have not yet received any negative feedback from other users.
    Error 15 is an error message from GRBL. Are you sure you have GRBL version V1.1 ?
    Does the error appear every time the button is pressed or only sometimes?
    I'll make you a video tomorrow to show how it should work.
  20. #140
    May 2016
    332
    Release notes V3.29
    A new version V3.29 is available for free download on my dropbox. -> bit.ly/2xF1KJ8_GrblGru_Release
    Most of the changes concern the lathe operation. The coordinate system has been adapted to the standardized XZ system.
    Creating jobs now works in the same way as when milling. Now also templates for turning chamfers and radii have been added.
    Suggestions for other useful templates are welcome.
    When milling, internal geometry data can now also be exported as SVG and G-Code can be imported as data.
    I also started to include OpenSCAD.
    Have fun with GrblGru
  1. Affordable CNC Mills and Lathes
    By cweber in forum Uncategorised MetalWorking Machines
    Last Post: 04-20-2013, 10:44 AM
  2. D&M Lathes, Mills, etc.
    By boatlover in forum Benchtop Machines
    Last Post: 04-25-2008, 02:39 AM
  3. Birmingham Mills and Lathes
    By smilenbseen in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2007, 01:19 AM
  4. Birmingham Mills and Lathes
    By smilenbseen in forum Vertical Mill, Lathe Project Log
    Last Post: 01-02-2007, 01:42 AM
  5. Darn near FREE LATHES!!!! - 2 lathes, gotta go NOW!
    By mxtras in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2006, 07:43 PM
