585,982 active members*
4,667 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > TB6600HG Stepper Driver Alert LED Lit Up, Motor Not Working?
    Aug 2015
    Hi all, I have a cheap stepper driver that I can't find elsewhere aside from the eBay auction that I bought it from so I can't find any documentation. It was working fine previously, but I went to begin a cut and it didn't move the motor, and the "warning" LED lit up, which is connected to the "ALERT" pin of the TB6600HG chip. The datasheet for the TB6600HG says it is the "TSD/ISD Monitor Pin", (I guess it could mean thermal shutdown and current shutdown, but i'm unsure), but I am not very good with electronics, and don't know what caused this or how to fix it, can anyone help?
    Josh
    1695
    Re: TB6600HG Stepper Driver Alert LED Lit Up, Motor Not Working?
    If you connected or disconnected the motors with the power on, you probably fried the chip. The chip cost more than the driver, so it is not worth fixing. Buy another.
  1. Need help, 3040z-dq & TB6600HG stepper drivers...
    By FrostByteUK in forum Chinese Machines
    Last Post: 09-29-2014, 09:33 PM
  2. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  3. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  4. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  5. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
