586,009 active members*
4,855 visitors online*
Results 1 to 1 of 1
    Jan 2014
    100
    Type 2 Canned Cycle
    Was wondering if this would be possible on a lathe.
    Using a G71 canned cycle type 2 with cutter comp on G42?
    Simple thread relief undercut on od of part. \____/ <<<Somewhat how the geometry is.
    Now would the control know to compensate on the right side of this undercut or would it leave it wider since I am using G42?
    I've been meaning to try this just haven't had the time. I am going to program the undercut with CAM software and run the CAM program after I manually program this on the control to see if I get the same result. I would just like to know if anyone on here has done this before or tried it. If possible maybe even give some tips.
    Thanks!
