M339 turns thru-spindle air blow on and I have not found any other code than M9 to turn it off. However, there is this massive design flaw that when M9 is executed, it flushes coolant through the spindle right on the hot inserts! Is there any undocumented M-code to turn the air blow off without switching to the coolant pump and if not, what would be the best way to fix this thing?
