584,814 active members*
5,235 visitors online*
IndustryArena Forum > CAM Software > Vectric > bmp and png files dont show up for loading
    Oct 2014
    97
    IN vcarve desktop. 8.0 I am trying to
    use the trace bitmap tool to create vector outline but in local files where the xxxxx.bmp should show up in the windows file structure vectric sees nothing.....file exorer shows that it is out there.....
    Thanks Dave
    Jan 2011
    188
    Re: bmp and png files dont show up for loading
    You have to start a new project then hit FILE / IMPORT / IMPORT-BITMAP
    Then it will list raster formats
    If you hit FILE / OPEN then it only lists vector formats
    www.signtorch.com
    Oct 2014
    97
    Thanks SignTorch , on first try File >New then when a clean slate opened File>Import opened a submenu with the >import bitmap option greyed out......but after closing the Vectric pgm and reloading , things worked right .....I could instantly see all the raster files and instantly load one...
    Thank you Much !
    Dave
  1. Loading Files into the laser... Freezing up Gweike 1290
    By ffokazak in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-13-2013, 05:37 AM
  2. Loading as split files.....
    By jcowie in forum Fanuc
    Last Post: 12-07-2010, 02:29 AM
  3. Discovery 308 Loading Files
    By jthornton in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2010, 09:43 PM
  4. New to EMC2, New to Linux Trouble loading SIM files
    By CalG in forum LinuxCNC (formerly EMC2)
    Last Post: 03-22-2009, 01:25 PM
  5. Mach 2 not loading files
    By JFettig in forum Mach Software (ArtSoft software)
    Last Post: 11-10-2007, 10:35 AM
