Hello, I hope I'm posting this in the correct forum.
Ok my concern is about servo motor makers. Since I'm doing a retrofitting on a industrial gantry CNC plasma/oxy fuel cutting machine, I have opted for a DMM Tech servo motors with absolute encoders. Those would be 2 servos for the Y axis movement and one servo for the X axis movement. The machine is quite big, as it have tracks for travel longitudinally 10000mm (Y axis) and it is 5000mm (X axis) large. The overall weight is about 800 kgs.
Now my idea is to use 2 servos of 1 kW for Y axis, and 1 servo of 750W for the X axis. The X axis will have to move about 3 torches alltogether. (2 separate torches for oxy fuel, and 1 plasma + 1 oxy fuel torch).
DMM Tech have servo motors up to 1,8kW which can fit perfectly for this job, but in the second place I want to extend this machine to have also a drilling/milling device on it. Since we work with big and thick steel plates , with high hardness (ranges from 300HB up to 600HB) we will need big forces for the drilling milling unit. This unit is planned to have a bigger servo motor for the spindle, with power in a range of 7,5kW most probably. And another servo motor for the Z axis (up and down movement of the spindle).
My question is, is there any problems to mix the servo motors from different producers, for example we have some DMM Tech servos but then in the second place we will add some
Panasonic/Yaskawa/Delta or other producer servo ? We plan to use Linux CNC (EMC2) to drive this.
Thanks in advance for the suggestions.
