585,717 active members*
4,031 visitors online*
    May 2016
    19
    Need Daewoo Puma 8s parameters
    I have lost the parameters on my Puma 8S lathe OTC control (1996) due to faulty spindle amplifier. Had the amplifier repaired and parameters are now gone. I have the back-up disk but all of the locked parameter such as the 900 numbers are missing. Must have been copied wrong. Anyone have the parameters for this machine? I have to load them manually because something is wrong with the RS-232. Also need the sequence to load them. Seems I need to load the 900 numbers first and so on. Thanks
    Jul 2010
    Re: Need Daewoo Puma 8s parameters
    Haven't been here in a while. Do you still have a problem?
    btw for all who read this, when you punch or output the parameters from a Fanuc 0 control, if you hold the EOB button when you tell the control to punch, it will include the Option parameters. I don't believe this is in any of the manuals.
    May 2016
    19
    I found them nestled in the cabinet of the machine. I had the disk but it was missing the 99 numbers. Thanks
    Apr 2018
    Need help too!
    I have a 1996 Puma S8 OTC control. The parameters are lost. I have the paper with the optional parameters, I'm hoping someone can help. It's just a boat anchor now..
    Thank you.
    May 2016
    19
    Quote Originally Posted by AIRPOINT View Post
    Need help too!
    Thank you.
    I may be able to help you. I do have the parameters. Send me a message and I will fix you up.
    Also the people at Fanuc America can walk you through the process if you need help, Tel: 888-FANUC-US (888-326-8287)
  1. Need help, Daewoo PUMA 6 s missing parameters
    By RTS_Norway in forum Daewoo/Doosan
    Last Post: 11-04-2019, 03:33 AM
  2. daewoo puma 10s parameters list
    By azizcom83 in forum Daewoo/Doosan
    Last Post: 04-11-2016, 01:22 PM
  3. Daewoo Puma 250B parameters
    By bluej_x in forum Daewoo/Doosan
    Last Post: 11-06-2013, 09:15 PM
  4. Need Daewoo Puma 230MS parameters
    By fm.ind in forum Daewoo/Doosan
    Last Post: 10-17-2012, 12:12 AM
  5. Daewoo Puma 200
    By williamsxu in forum Daewoo/Doosan
    Last Post: 01-17-2007, 11:52 PM
