584,812 active members*
5,575 visitors online*
Results 1 to 2 of 2
    Oct 2008
    9
    Modified Macros
    Hi Gerry
    Attached are the macros I have modified if you can review and make any changes or recommendations I would appreciate it. This is my first attempt at modifying macros.
    Bill I
    M884
    DoButton( 24 )
    Code "G53 G0 Z-2"
    'While IsMoving()
    'Wend
    DoButton( 23 )
    Code "G53 G0 Y1.25"
    'While IsMoving()
    'Wend
    DoButton(22)
    Code "G53 G0 X4.0"
    'While IsMoving()
    'Wend
    DoOemButton(1008)
    DoOemButton(1009)
    M885
    DoButton(22)
    Code "G53 G0 X4.0"
    DoOemButton(1008)
    M886
    DoButton(23)
    Code "G53 G0 Y1.25"
    DoOemButton(1009)
    M887
    DoButton(24)
    Code "G53 G0 Z-2"
    While IsMoving()
    Wend
    DoOemButton(1010)
    35538
    Re: Modified Macros
    M884
    DoButton(24)
    DoButton(23)
    DoButton(22)
    Code "G53 G0 X4.0 Y1.25 X-2"
    While IsMoving()
    Wend
    DoOemButton(1008)
    DoOemButton(1009)
    M885
    DoButton(22)
    Code "G53 G0 X4.0"
    While IsMoving()
    Wend
    DoOemButton(1008)
    M886
    DoButton(23)
    While IsMoving()
    Wend
    DoOemButton(1009)
    M887
    DoButton(24)
    Code "G53 G0 Z-2"
    While IsMoving()
    Wend
    DoOemButton(1010)
    Typically, you don't want to zero the axis in the homing macro.
    Normally, if the machine loses position, you can home it to get position back, and continue.
    When you zero the axis after homing, you can no longer do this, as you then need to "find" your origin again.
  1. Need some pins modified.
    By mrquacker in forum North America RFQ's
    Last Post: 03-10-2014, 08:23 PM
  2. Modified cnc 3020
    By BOATDUDEGUY in forum DIY CNC Router Table Machines
    Last Post: 08-02-2013, 01:17 PM
  3. Another modified Momus
    By skylanehku in forum Momus Design CNC plans
    Last Post: 05-30-2013, 11:58 AM
  4. G76 Modified Threading
    By lathe_man in forum Hardinge Lathes
    Last Post: 04-29-2010, 12:25 PM
  5. Another modified Joe's 2006 CNC
    By DeWalt58 in forum Joes CNC Model 2006
    Last Post: 03-20-2008, 10:44 AM
