585,978 active members*
4,336 visitors online*
    Oct 2009
    59
    3D SCANNER NEED
    Hello to all,
    My company elaborates marble, and we have a cnc maxima 5axis cms, and a waterjet.
    Our customers often give us carbon patrons of marble which need to be cut in waterjet.
    Until now we take a picture of the patron and then using autocad and splines we design the part. But the results is not always good.
    For this reason, we want to buy a scanner to trace the contour of patrons.
    Can you please point me a product for this job?
    Please check pictures of sended patrons, please note sometimes patrons are bigger in length, (like marbles around the pool.)
    Some products I found will do the job?
    1) Portable 3D Scanners for 3D Scanning | HandySCAN 3D by Creaform
    2) https://www.fuel-3d.com/
    3) Sense 3D Scanner | Features | 3D Systems
    Best Regards
    Platon Kiriakidis
    Attached Thumbnails Attached Thumbnails 2016-07-13 12.26.01.jpg   2016-07-13 12.27.03.jpg
    Feb 2009
    2143
    Re: 3D SCANNER NEED
    You would get good results from patterns like that with a NextEngine scanner. I think the price/performance may be one of the best options. This is if you don't need to do the scanning in the field and have a lot of flexibility. The HandyScan may work much better, but is likely many multiple times the cost of the NextEngine - you need to determine that cost is justified.
    Note as well that "all" a scanner does is give you a pointcloud. You then need to translate that pointcloud in to a CAD file of the profiles you want. MAKE SURE you investigate the method of creating the CAD file in addition to "just" capturing the pointcloud. You need to be comfortable with the solutions for ALL STEPS needed. I would get as many hands on demos as you can and actually do the work yourself (don't let them "show you how it is done", as the software can be quite challenging and have a VERY steep learning curve!).
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Apr 2004
    5737
    Re: 3D SCANNER NEED
    It's not clear that you really need a 3D scanner for what you're trying to do. It looks like you're trying to capture a simple 2D contour and and make a 2D pattern (or "patron") from it that you can transfer to the waterjet machine for cutting. None of the tools you've indicated do anything like that. I'd suggest getting a contour gauge instead: Contour Gauge | Grizzly Industrial
    To use it, you just push it up against the part and lock down the pins. You can then trace it to make cardboard templates, or copy it in AutoCAD. If you wanted to copy a statue or something else that's three dimensional, and carve it with your CNC mill, that's when you'd need a 3D scanner.
    Andrew Werby
    Website
    Mar 2017
    Re: 3D SCANNER NEED
    there are many companies offer 3d scanning so i suggest look at on the nearest company in your area.
    Jul 2017
    22
    Re: 3D SCANNER NEED
    3D scanning is the part of what's holding 3d printing back, it is one of the powerful education tool. Most People use open social platform like thingiverse to download 3d print. It makes scanning much useful and easier.
  1. Anyone using USB Scanner/Camera with PathPilot (Scanner Function)?
    By ehpepper in forum Tormach PathPilot™
    Last Post: 04-27-2016, 09:01 PM
  2. Galvanometer Scanner/ Galvo Scanner
    By grace cao in forum Laser Hardware
    Last Post: 11-28-2013, 06:52 AM
  3. cad/cam and 3d scanner
    By sterlin in forum Want To Buy...Need help!
    Last Post: 01-08-2013, 05:53 PM
  4. cnc scanner
    By SomeWhatLost in forum Tormach Personal CNC Mill
    Last Post: 09-14-2012, 07:27 PM
  5. scanner
    By bruha in forum Mastercam
    Last Post: 01-18-2007, 04:11 PM
