584,861 active members*
4,717 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Can't engrave text in fusion 360 because of tool choice!! HELPPPP
    May 2016
    9
    Hello everyone, I'm losing my mind over here I'm just trying to run a test pass and engrave the word test into a piece of scrap aluminum in fusion 360, however once cad is finished and I get to where I make tool choice fusion try's to make me select a chamfer mill, I did try to select it to see what would happen but then you get to entering the sizes of your tool and it won't change its set at .5! Am I doing something wrong, I tried to change it to .124 and it changes right back.. I have two spring loaded engraving tools, 1 is the tormach TTS diamond engraver assembly and 1 is the spring loaded tool that holds the small 1/8" engraving bits.. I don't understand why it won't allow me to select these tools or at the very least enter their sizes, I would like to do NFA engravings to make a little extra cash I'm a master gunsmith with an FFL and have just broken into the machining side of things.. I have always used manual machines so cnc is quite new to me any help fellas!!
    Sep 2009
    1856
    Re: Can't engrave text in fusion 360 because of tool choice!! HELPPPP
    you have to make up a bull**** chamfer mill all you need to do is make sure the sizing is the correct and the angle, the angle is to 90 not from 90 so a 60 degree is 30 degrees you need to make the tool first. just did it for a test
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    May 2016
    9
    Quote Originally Posted by daniellyall View Post
    So basically I have to add tool, but not really cause I'm still choosing a chamfer mill lol. Instead of what I'm using.. Alright then I'll give it a go..
    Sep 2009
    1856
    yep it's a pain have V carve bits that are called chamfer mills I just makes sure the size's and angle are correct and they work fine
    [SIGPIC][/SIGPIC]
  1. Fusion text options
    By naytep in forum Autodesk CAM
    Last Post: 05-06-2016, 04:58 PM
  2. Autodesk Fusion 360 aligning text
    By m1n1m in forum Autodesk
    Last Post: 12-20-2015, 03:19 AM
  3. TEXT/ENGRAVE ON VARIABLE Z
    By garylb in forum OneCNC
    Last Post: 03-11-2011, 08:13 AM
  4. Need help bad, How do I engrave text
    By 2Bits in forum Dolphin CAD/CAM
    Last Post: 03-11-2009, 03:40 AM
  5. Rhino engrave text on curved surface
    By replicapro in forum Rhino 3D
    Last Post: 03-11-2008, 06:32 PM
