585,914 active members*
3,929 visitors online*
    Apr 2016
    102
    Codes for manual tool changes
    Hi All
    My first post in the WinCNC section of CNC zone.
    I used a friend of mines Shop Sabre 7214 router today with WinCNC, I went armed with NC code produced in BobCAD V28 using the Shopsabre post supplied by BobCAD.
    As soon as the control got to the line no 6 with T1 in it stopped and said missing file. I got over the problem by manually editing T1 out and then doing a seperate NC file for where tool 2 was called up.
    I dont like not understanding this. I had hoped to do a manual tool change and set T2 onto top of stock as per T1.
    G90
    G0 Z10.
    G0 X0 Y0
    M5
    M51
    T1
    M3
    S15000
    G4 X4
    M50
    >>>>>>>>> cont.
    So I downloaded a post file from WinCNC to use with BobCAD and that turned out the following code which never called up a tool as far as I can see, does not even look like it has started the spindle!!
    [ PROGRAM NUMBER: 100 ]
    [ PROGRAM NAME: VAC BED TOP WINCNC.NC ]
    [ POST: WINCNC ]
    [ DATE: TUE. 07/19/2016 ]
    [ TIME: 02:23PM ]
    [12.2mm MDF]
    [Grid will cut 3.5mm deep]
    [Circular hole will not break free to save damaging cutter]
    [Outer will be done in two passes with a tab at either end]
    [ T1ENDMILL ROUGH , DIAMETER = 3. , LENGTH = 45. ]
    [ T2ENDMILL ROUGH , DIAMETER = 6. , LENGTH = 60. ]
    N01 G90
    N02 G53
    N03 G54
    [Machine Setup - 1 Profile Rough]
    [GRID 1]
    N04 G00 X63.75 Y335.
    N05 Z5.
    N06 Z2.5
    N07 G01 Z-3.5 F500.
    N08 Y55. F2000.
    So my question is how do you do a manual tool change with the WinCNC control ie what code do you use, for the life of me I have not been able to find the info.
    Once I know what is required in terms of code then I will edit the BobCAD post to get the correct code.
    Many Thanks
    Barrie
    Mar 2008
    1762
    Re: Codes for manual tool changes
    The machine could be setup as a single tool machine. To determine if this is true, open the CNC.MAC file in a text editor and see if or which macro is assigned to T1,2,3,4,etc.
    Single tool machines will not have a macro assigned to tool numbers, manual or ATC will.
    Assuming there is a macro assigned, verify that that macro actually exists in the location specified.
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Apr 2016
    102
    Thanks will investigate next time I am there.
    Barrie
  1. Comet VMC tool change and M-codes
    By guhl in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-07-2014, 04:31 PM
  2. Wasino lj103m manual or M-codes
    By Elmss12 in forum Machinery Manuals / Brochures
    Last Post: 02-01-2014, 01:02 AM
  3. Anybod have a jetmatic Or know where I could find a manual of the codes?
    By madman270 in forum Uncategorised MetalWorking Machines
    Last Post: 10-31-2010, 02:49 PM
  4. Replies: 2
    Last Post: 04-07-2010, 02:46 AM
  5. manual imputing codes Denford GE Fanuc series OM
    By scorpiorichard in forum Uncategorised MetalWorking Machines
    Last Post: 12-01-2008, 04:37 PM
