585,974 active members*
4,188 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Importing .stl stock into RhinoCam 2016
    Jul 2009
    10
    Smile Importing .stl stock into RhinoCam 2016
    Does anyone know if RhinoCam 2016 will import .stl stock to machine? I know that VisualMill 5.0 would. Not sure about the RinoCam 2016. Someone told me that you could only use part or box stock. I would like to bring in the Model stock to machine. Thanks.
    Apr 2004
    5737
    Re: Importing .stl stock into RhinoCam 2016
    If you have the Pro or Premium version of RhinoCAM 2016, you can create a stock model using the "Stock from Selection" function. Just click that box, then select the object you want to designate as stock; it will automatically mesh it and use it as a stock model, as long as it's watertight. But even if you don't have Pro, there are more options for stock than Part or Box.
    Andrew Werby
    Website
    Jul 2009
    10
    Smile Re: Importing .stl stock into RhinoCam 2016
    Thank you so much for the reply. That is good to know.
    Jan 2016
    25
    it might import the file but by mecsoft australias own admission isnt very friendly although a rhino plug in hates stl files
    NCGCAM for stl files it takes minutes to program a pass excludes ALL tool collisions automatically
    just going off my experience and hords of emails telling me im disillusion thinking rhinocam is a silver bullet fix to stl files and that im IGNORANT to think otherwise
    25k down the drain
    i will admit mecsoft usa Uday is fantastic to deal with but getting up at 2 am to fix a problem just doesnt suit id expect they get up at 2am for that price
    Australian mecsoft are useless
  1. Replies: 1
    Last Post: 08-10-2018, 11:21 AM
  2. Replies: 3
    Last Post: 06-17-2016, 04:55 PM
  3. JCUT machine 6090B $1899 & JCUT-1325B $3199 only valid from 2016.6.1-2016.6.10
    By chinacut in forum DIY CNC Router Table Machines
    Last Post: 05-30-2016, 09:25 AM
  4. Importing 3D stock into Visual Mill 6.0
    By Boxey45 in forum Visual Mill
    Last Post: 05-25-2015, 05:53 PM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
